Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 03-12-2016, 11:02 AM   #1
1989 32' Excella
Sharon Springs , New York
Replacing Coleman Delta TX A/C, what fits?
As stated the AC unit in my 1989 Excella is a Coleman Delta TX, the drip pan/condensation tube appear to be in good shape. The unit looks to be a 13.5k BTU system w/heat strip and I'd like to replace it with an updated 15k BTU system w/heat strip. Is there a direct replacement available that utilizes the current drip pan/ condensation tube design and fits seamlessly into the 14" x 14" roof opening. Any info would be appreciated.
JDB
MAJORJDB is offline   Reply With Quote
Old 03-12-2016, 04:43 PM   #2
1989 32' Excella
Update, called PPL about a Coleman Mach 8 and told them I was also considering a Dometic Penguin, apparently the wiring is different so it looks like its the Mach 8. PPL suggested I call Coleman to make sure the unit will fit my rig with no issues. Any thoughts on the Mach 8 would be welcome...
JDB
Coleman A/C replacing Coleman A/C? Easyrider06 Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-11-2015 06:41 AM
Replacing Coleman Delta TX 13500btu A/C tr674 Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-23-2014 08:50 PM
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
Looking for Control Module-Coleman Delta TX DataMover Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2009 02:48 PM
Coleman Delta TX - Repair? Ganglin Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-15-2007 04:06 AM
