09-24-2018, 06:54 PM
2019 Basecamp
Plano
, Arkansas
No furnace option on thermostat
I bought a used 23’ safari se. My furnace doesn’t work and there is no mode option on the thermostat for a furnace. I do have an attwood furnace in the trailer. It doesn’t work. The fuse box says furnace and running lights are on the same fuse, and the running lights work. Any info. Would be appreciated.
09-24-2018, 07:46 PM
2013 23' FB Flying Cloud
Jericho
, Vermont
See if it has an Aqua mode. If so, hit up and down arrows together and it might switch to furnace mode.
Dan and Chris (and Lindy and Milo)
2013 Flying Cloud 23FB
2014 Tundra DC 5.7L / ProPride / Tekonsha P3
2000 25' Safari
Davidson County
, NC Highlands County, FL
Running lights are powered by the tow vehicle.
Furnace is powered by trailer's 12 volt electrical system, through the converter and/or battery.
What year model is your Safari?
Does your trailer have a heat pump, or is it air conditioner only?
Alan
09-24-2018, 07:55 PM
2013 20' Flying Cloud
Westerly
, Rhode Island
I must have hit those together by accident recently. That had me stumped for a few minutes until I randomly pressed both arrows and got Furnace back on the menu! I probably would have pushed buttons for another hour before breaking down and reading the manual. What is Aqua mode?
09-24-2018, 08:15 PM
2019 Basecamp
Plano
, Arkansas
2007 and yes it has a heat pump.
09-24-2018, 08:18 PM
2019 Basecamp
Plano
, Arkansas
I’ll try that. I don’t know what aqua mode is. Never heard of it but I learn something new every day it seems.
09-24-2018, 08:32 PM
2019 Basecamp
Plano
, Arkansas
It does have a heat pump. 2007 23’ Safari SE
09-24-2018, 08:45 PM
Retired.
, At Large
There was a recent thread that discussed this. The CCC2 thermostat has three languages, English, French, and Spanish. You cycle through them by depressing the up and down buttons simultaneously.
09-24-2018, 09:14 PM
2000 25' Safari
Davidson County
aqua mode = a thermostat setting used when there is hydronic heating in lieu of the furnace
you can download a manual here;
https://www.dometic.com/en-us/us/pro...#documentation
Alan
09-24-2018, 11:49 PM
Sag Harbor
, New York
. . . before breaking down and reading the manual.
09-25-2018, 05:28 AM
2019 Basecamp
Plano
, Arkansas
My thermostat looks like this
09-25-2018, 06:16 AM
2012 25' Flying Cloud
Berlin
, Maryland
I had a similar problem when they replaced my AC unit. They failed to properly set the switches on the roof unit. I took the cover off set the switch and all was well, however I do no have your thermostat.
09-25-2018, 07:15 AM
2000 25' Safari
Davidson County
This is a link to the manual for your thermostat>
https://assets.interactcp.com/fretzr...rol_Manual.pdf
Alan
09-25-2018, 10:19 AM
Experienced Learner
2000 34' Excella
Somewhere
, Earth
Have the same thermostat connected to an original Penguin 13.5 BTU with heat-pump. It operates the same as the newer models, toggling between Fan, AC, Heat Pump, Furnace.
Spoke with Dometic support while researching options for replacement and was told that the Furnace option only appears if the control board in the AC unit itself sees a Furnace connected, which is what @urnmor indicated in his post. The thermostat is connected to the control board via an RJ-11 style telephone cord, so if it's working at all the issue will be with the control board in the main AC unit.
It is also possible to install a newer AC with a control board that interfaces with the original Comfort Control thermostat. If the AC has been upgraded and the original thermostat left in place, something may not have been connected during the swap.
You can always contact Dometic support with questions. I have called half a dozen times with various inquiries, and while not everyone knows everything, on several occasions the representative was able to speak with a tech person offline and get answers to even very specific technical questions. Overall quite impressed with their support.
RV owners and end-user customer support @ 800.544.4881
09-25-2018, 12:37 PM
2006 19' Safari SE
Tucson
We had this happen, too ... when we replaced the AC and got a new thermostat.
Read your thermostat's manual (if you have it ... if not you should be able to find it online)...that will give you directions to reset it or trouble-shoot as needed...I had to do that as well.
Good luck. This stuff is frustrating.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
09-25-2018, 03:09 PM
Washington
, Missouri
It's a long shot but on our maiden voyage night 2, I had a stat that turned on the furnace and the AC at the same time. I suspect pushing buttons I should not have. However a hard re-boot to factory specs solved the issue. I discovered instructions in the stat manual (Dometic). The furnace is a Atwood 7920-II Hydro Flame.
Happy Trails
09-25-2018, 06:33 PM
2019 Basecamp
Plano
, Arkansas
Thanks , that’s a lot of good info for me to look into. I have a feeling the ac was worked on before I bought it. I noticed what looked like a hanging phone line under the inside vent filter cover. Also my ac condensation tube isn’t connected to anything. Ac just drains out on the roof. Some prior owner had some kind of work done.
09-25-2018, 08:55 PM
Experienced Learner
2000 34' Excella
Somewhere
, Earth
Your feeling is likely correct, and it sounds like things weren't quite put back together properly.
Just so you know, if you do have someone service the unit, there is a pretty simple solution for the condensation issue: https://www.vintagetrailersupply.com...-p/vts-079.htm
09-30-2018, 12:10 PM
2019 Basecamp
Plano
, Arkansas
I want to thank everyone for your valuable information. I can’t thank you enough. My furnace is now working. The DIP switch on the AC Circuit board was turned off for the furnace. When I flipped that switch up the thermostat recognized the furnace. Just had to clean up the dirt Dobbe from the furnace vent. I turned on the gas turned it on at the the thermostat and everything fired up. Thanks again.
Daniel Borgman, Plano Texas
12-03-2019, 06:29 PM
2015 19' Flying Cloud
Columbus
, Ohio
We just had the same thing happen. We did the master reset only to see everything disappear too. Checked with the KOA and they had a RV mobile repair tech in the area. Guess it's common that KOAs have a local business RV tech number available. Long story short, when he looked at it, it decided to work again? However, I asked him to check the telephone wire people were talking about in this thread. He noticed the alignment of the wires in the jack, one of the wires looked to be recessed not allowing for good contact. He re-terminated the connection ( cut, replaced jack for a new tight aligned connection). You would need to get a tool from a place like Lowe's to be able to fix it. YouTube videos will show you how if you are a DIY person. I took a picture to show location and what it should look like when right. Not sure I can post photos. However, you would need to YouTube telephone jack termination to understand how to DIY. Good luck!
