Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-07-2020, 04:23 PM   #1
Flower Mound , Texas
Dometic Penguin 2/ Armstrong Replacement
Greetings -
I'm planning to replace the original Armstrong T-10 with a Penguin 2 in my '64 Globetrotter. To those that have experience with this process, what challenges can be expected with the retrofit?
- how much cutting can be expected?
- will additional support bracing be required?
Any insight would truly be appreciated.
Speckc is offline   Reply With Quote
Dometic Penguin Heat Pump Replacement kavosCCD Electrical - Systems, Generators, Batteries & Solar 1 08-09-2017 06:26 PM
2006 Dometic Penguin Drain Pan replacement? yogijames General Repair Forum 2 06-27-2016 09:48 AM
Penguin I to Penguin II drain pan? HiJoeSilver General Repair Forum 1 05-25-2015 04:51 AM
Dometic Penguin A/C Main Cycle Board Saigon Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-03-2004 02:20 AM
Dometic Penguin for '66 Safari? markh8624 Furnaces, Heaters, Fireplaces & Air Conditioning 21 02-24-2004 05:30 PM
