Old 05-07-2017, 11:12 AM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Here is the AC unit in the bathtub. It has wheels and weighs about 45 pounds. Not too bad to move if I want to.It has only been 80s here so not a true test but it did cool the trailer to 68 in a short time.
90s with full sun will be the real test.
Happy with is and you can barely see the vent through the back window.
ID:	284954   Click image for larger version
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-11-2017, 08:54 AM   #22
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
finally hit temps in the mid to high 80s today. The Airstream was pretty hot inside. With the ac on 73 it cooled down quickly.. SO glad.
I am struggling a bit with the vent out the back window. I think I will put a sheet of plexiglass in there instead of the screen and attach the vent to it with small screws. That should work and I can remove it in the cooler weather.
AIR #005
retired!
Old 05-11-2017, 10:53 AM   #23
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
If you had a hidden place to cut a hole in the floor and run your hose and drain there, (with a screen to keep critters out), that would be a spiffy setup!
WayneG is offline   Reply With Quote
Old 05-12-2017, 08:38 AM   #24
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I saw an install on the web with a sheet of plexi in the back window, same as my plan. Looks good. My trailer has a plexi window that has lasted well for more years than I have owned it...6
AIR #005
retired!
Old 06-24-2017, 03:42 PM   #25
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
bought the plexi for the portable ac unit vent today. 20 bucks from Lowe's. Cut to size.
I got new screen clips to hold it in the window frame, and will cut a small hole for the vent hose and put foam insulation around it.
Should work well.The air conditioner is very quiet.
I saw the same models at Lowes while there, quite a bit more $$.
AIR #005
retired!
Old 06-25-2017, 10:44 PM   #26
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
115° today in PHX, AZ and my 15,000 btu have a really hard time cooling today as I am trying to leave to OURAY, CO. were its 75°.
I would not spend the money on use one w/ no warranty.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 06-26-2017, 04:55 PM   #27
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I paid 100 for a unit that cost 350 at Lowes. Warranty? No big deal.
AIR #005
retired!
Old 06-26-2017, 10:25 PM   #28
dames7's Avatar
GILBERT , Arizona
That's not a bad price, good luck.
David & Nancy Ames
2015 FC 25' RB
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
