I am probably wrong but looking at the wiring diagram for the stated unit it appears those two gray wires are the thermostat circuit for the heater...and they do NOT attach to the main control thermostat inside of the trailer. [The main control thermostat has about 7 small colored wires inside of an insulated sheath which runs to the relay box on the roof unit and are connect via a RJ45 coupler.] When the thermostat calls for heat, the small white wire from the control thermostat causes a relay inside of the roof unit box to activate, connecting the two heater T-stat wires together.
Given your compressor engages, I agree with J Morgan that you are highly likely dealing with a replacement and upsizing is not an issue.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
