Hi I'm trying to see how other people are renovating their bathrooms. I've attached a image of mine but I'm looking to modernize it a little more. I plan on removing the closet and possibly replacing it with a step in shower basin or moving my sink over, but what do I do with the exposed vent pipes???? Hmmmm??
We renovated our 66 Safari’s bathroom. We removed everything and re-coated all the thermoplastic. We basically kept the same design layout. In your case, try and reroute your vent pipe through the adjacent closet outside the bathroom. Also, you can keep your routing and cover it with an aluminum shroud. You’ll just have to see how far you can go with the way you want it in the end. You may have to make a few compromises. Good luck
Your 23 safari bath was a wet bath style in which we found the corner closet
not usable. I removed the closet and installed a custom 2 pcs. shower in that
location.
These pics were during the build stages. Hope this helps!
