Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 1969 - 1973 Safari
Old 10-23-2021, 12:58 PM   #1
1972 23' Safari
Middletown , Rhode Island
Vintage safari bathroom renos?
Hi I'm trying to see how other people are renovating their bathrooms. I've attached a image of mine but I'm looking to modernize it a little more. I plan on removing the closet and possibly replacing it with a step in shower basin or moving my sink over, but what do I do with the exposed vent pipes???? Hmmmm??
ID:	406808   Click image for larger version
Mx468 is offline   Reply With Quote
Old 10-23-2021, 01:22 PM   #2
1966 22' Safari
Fredericksburg , Texas
We renovated our 66 Safari’s bathroom. We removed everything and re-coated all the thermoplastic. We basically kept the same design layout. In your case, try and reroute your vent pipe through the adjacent closet outside the bathroom. Also, you can keep your routing and cover it with an aluminum shroud. You’ll just have to see how far you can go with the way you want it in the end. You may have to make a few compromises. Good luck
Bubba L is offline   Reply With Quote
Old 10-23-2021, 06:17 PM   #3
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Not sure this helps if you want to save some of your pieces, but here's what I did; before and after.
Toilet in shower on left, sink cab in middle, closet to the right.
Name:	bath shower toilet combo.jpg
ID:	406821 Click image for larger version
Name:	Bath sink cab closet door on right.jpg
ID:	406822 Click image for larger version
Name:	Bath closet.jpg
Tub with hand held shower on left, toilet (macerating) in middle, sink cab to the right.
ID:	406826 Click image for larger version
ID:	406824 Click image for larger version
Name:	Bathroom sink cab.jpg
After photos during construction before all plumbing was hidden behind finish panels.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 10-31-2021, 08:26 PM   #4
1972 23' Safari
DESHLER , OH
Send a message via MSN to deanv76
23 Safari Bath Redo
Your 23 safari bath was a wet bath style in which we found the corner closet
not usable. I removed the closet and installed a custom 2 pcs. shower in that
location.
These pics were during the build stages. Hope this helps!
ID:	407303   Click image for larger version
ID:	407305   Click image for larger version
deanv76 is offline   Reply With Quote
Interior renos Livinitup General Repair Forum 1 05-24-2021 10:11 AM
Has anyone used rustoleum stainless steel in thier shower renos? TPickerl Sinks, Showers & Toilets 4 01-16-2014 09:48 PM
Bathroom vanity and Bathroom vent lights... sovereignrwe Electrical - Systems, Generators, Batteries & Solar 10 01-05-2010 06:30 AM
