So we may have talked about this topic a time or two, maybe to the point of ad nauseum. But, important topics should be discussed thoroughly to ensure everyone's safety.
List your trailer's length, weight, tongue weight, and your usual additional cargo load. And then tell us, in detail, what you pull it with. Also mention details concerning your hitch setup.
Then tell us if you think your idea of what the minimum TV setup would be.
For example, here are my specs:
1976 31ft.
Sovereign, ~8000lbs ready for travel (nobody cares about dry weight), 900lbs tongue weight, roughly 900lbs of passengers, dogs, and cargo. Also, 200lbs for my camper shell.
TV is a Dodge Ram 2500 w. Cummins 24v turbodiesel. My hitch is a WD setup of unknown origin (came with the trailer, but works like a champ).
BARE minimum I would tow with:
The equivalent of a Ford F150 max tow/max payload, minus my camper top, and most cargo moved into the trailer over the axles. WD hitch, and 3.5 EB OR 5.0 V8.
