Originally Posted by Gene
The maximum pressure is set by the manufacturer and they take into account the normal heating up of the tire during use. The maximum pressure is not the best pressure for most people. Do your research for your vehicles. Tires pressure increases from 5-12 lbs. I am guessing from memory. It depends on which side faces the sun, ambient temperatures and speed.
With summer temperatures increasing, travel in southern Arizona may not be the best idea in the future. Is there info on how hot various brands can get before they fail? With Phoenix temps seeming to be approaching 115-120˚, what is the limit for tires, A/C and people?
Living in the Phoenix area I feel eminently qualified to answer your questions. The limit for AC is around 100*. One would be able to cool a trailer enough to at least not die. The nights would be much more comfortable. Take note of the fact that through much of the I-10 route shade trees are virtually nonexistent I have yet to find the limit on tires. As noted in an earlier post the engineers have already factored the heat into the tire design and I see no reason to doubt them. I regularly travel, in the summer, through AZ, NV, NM, CA, well all of the western states, and have yet to experience a tire issue that was caused by heat. BTW I always run max inflation because I, like most people, usually travel near my max weight. It is good to remember that when one runs less than max psi they decrease the payload of the tires. People seem to be able to adapt to the temps in the summer here much the same way people in much colder climes do.We do less outdoors unless necessary, we travel to cooler locales and we drink lot of fluids and stay out of the sun. It's not as bad in the summer as you think, for prepared people.
Having said all that I still recommend a more northern route for the OP's journey. I never want to travel in conditions that I don't want to camp in. Also, while the heat is not in and of it's self bad, it will most likely find the weak link of your rig. The desert southwest is not a place to break down in the summer.
Good luck to the OP and have a safe journey.
Canyon
