Hi all!
I've been pouring over the forum the last few weeks in anticipation of picking up our 74' Silver Streak. She's in average condition- and after getting her home and beginning investigation- under the obscene wallpaper job I found water damage on paneling and subfloor.
I think I have found that most the leaking comes from the windows - all the weather stripping (not sure what it's called) between windows is dry and pulling out and there are water trails from the corners to wet areas. (I washed her and then we had a mega storm, go figure. But it was a good test.)
I found a few areas of rot in front of trailer and by door and am comtemplating whether a replacement floor is needed or just another sub floor placed on top.
I want to do it right... how does one determine how much rot warrants replacement? This hole is about 2 x 2.
Also what is the channel around base called? C channel?
I'm posting a pic because I think it needs to be replaced because it's split the L brackets are broken off and shell is detached from the channel in front. Let me know what you experienced restorers think.
Where do I get this at?
If I replace this I may as well do subfloor.
