05-27-2020, 09:33 PM
1975 Argosy 26
Normandy Park
Spring pull down shade over toilet?
How do I reinstall the spring loaded curtain? One side has just a pin the other more of a flat piece that clearly can be wound up so when you release it it automatically goes back up.
I can not figure how to do this.
Any help?
Dan Attachment 1
05-27-2020, 09:36 PM
1975 Argosy 26
Normandy Park
Meant to add the other one
Dan
05-28-2020, 04:27 AM
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral
The spring that puts tension on the roller is on the end with the flat bar. The female brackets from which the roller hangs has just a pin hole on one side but a slot on the other. You turn the flat bar (You will need to experiment with the number of turns) to create tension. Stick the pin side into its receiver, line up the slot end and place into its slot while preserving the tension. I'm sure that with practice its easy.
05-28-2020, 06:40 AM
1975 Argosy 26
Normandy Park
Is this done with the curtain rolled up or do you have it all down, tension it, insert so that it then rolls up on it’s own ?
05-28-2020, 09:30 AM
1964 30' Sovereign
Ione
, CA
When I've done this in our home, you place the rolled up curtain tabs in their slots in the brackets... But it is CRITICAL that you mounted the brackets on the correct sides and have the curtain rolling in the right direction.
The internal spring should be relaxed at this point.
By pulling the curtain down tension will be 'wound' into the spring. When you stop pulling, it should lock (internal stop mechanism) in place. Then to roll back up just pull down to release the stop mechanism.
If you need to put more or less tension onto the curtain, a technique is to just rotate the rolled up curtain a full turn.
Hope this helps!
Mark & Melanie Trowbridge
1964 Airstream Sovereign 30' (Double)
2004 Dodge Ram QuadCab 4x4 Diesel
05-28-2020, 09:34 AM
1976 Argosy 26
Los Altos
I have a similar shade in our Argosy. You would wind up the spring on the flat end as said with the curtain rolled up. This allows the mechanism to increase tension when it is pulled down. Our spring broke so I replaced the roller mechanism, but used the original shade material since I couldn't find any replacements that I liked. This cheep replacement's mechanism broke quickly, so I've ordered a roller shade mechanism to avoid the spring; hopefully this will work better. Hope yours isn't broken!
05-28-2020, 04:39 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Roll up the shade then put it in the bracket. To tighten the spring pull the shade down, remove from bracket wind up by hand, replace into bracket, carefully so you don’t trigger the spring, when installing. No tools needed.
