Bottom Curtain Tab / Slide Orientation
Hello,
I am in the process of getting new curtains for our front and back windows, and have a question on the orientation of the bottom tab/slide: Should the elastic be stitched in above the bottom track, so it pulls tight? Or should it be below and not have any tension on the elastic?
We currently have the bottom tabs sewn below so there is no tension on the elastic. The upper tabs are sewn in with ribbon. Here are some pictures of the bottom and top track.
Does some one have any pictures showing the orientation of the tabs/slides? We are replacing homemade curtains that had the tabs hot glued in place so don't have much to work off of.
Pictures:
1st is bottom track from inside
2nd is bottom track from outside
3rd is top track from inside
