Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 12-30-2010, 12:48 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Stainless steel screws instead of rivets?
I have an atwood 10 gallon water heater for my 1960 Overlander. I am going to put all the old exterior heating aluminum back on so it looks original. Since the exhaust is on the left instead of the right I am going flip everything over.
I want to put a solid sheet of aluminum over the orginal hole and cut out a perfect square to fit the water heater. I do not want any carbon monoxide coming back in. I don't have olympic rivets. I could use pop rivets but what I have read on the forum is they are for interior only.
Question:
Can I use stainless steel screws for the solid sheet of aluminum over the the old water heater hole. I do have pop rivets all sizes and a rivet gun. Can I use pop rivets?
Brian
Name:	hot water heater.JPG
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 12-30-2010, 01:27 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Brian,
The problem with pop-rivets is that they have a hole in the middle once you rivet them into place, so they tend to leak. You could fill the hole with vulkum, but that would look ugly imo.
When I installed new roof vents, and new running lights, I used stainless steel screws. They were recommended by our local AS dealer for the roof vents as well.
I treated them pretty much like Olympic rivets in that I shot a dab of vulkum in the hole before installing the screw. So, they should work just fine for you on your project. If you have access to the interior, you can add vulkum on the backside of each screw as well as added security against leaks. The only real difference I think between the screws and the Olympic rivets will be the look. Both will function well and not leak if sealed during installation.
Chris
Old 12-30-2010, 02:11 PM   #3
Lothlorian's Avatar
Chris:
What size screws did you use? The orginal holes had screws in them. I did not have to drill any pop rivets. I went out and bought aluminum angle iron 2" X 2". I will connect that to the interior wall. I will anchor the hot water heater to it. I may use the outside wall instead. I am putting the plan together as I go. This is what I plan to do.
http://www.vintageairstream.com/Imag...terinstall.jpg
My biggest concern is making sure exhaust does not leak back into the trailer.
Thanks for the info
Brian
Brian & Adrienne
Old 12-30-2010, 02:31 PM   #4
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I also would like to use stainless steel screw on some shelving and other projects on the interior. Does anyone know how long of a screw you can use on an inside wall? I sure don't want any screws sticking thru the outside.
DougZ is offline   Reply With Quote
Old 12-31-2010, 07:25 AM   #5
Minno's Avatar
1972 31' Sovereign
Brian,
I used #8, 1" long screws for the running lights, and #8 1 1/4" for the roof vents. The #8 screw is just the right size for an old rivet hole, as long as you don't over tighten it. But, match the screw size that was originally in the holes, or go one size larger. If you're drilling all new holes, then I would use either #8 or #10.
If you make the installation look like the picture you posted, then you will have no chance of fumes getting back into the trailer. Be sure to seal the seams with vulkum or parbond or some other AS seam sealer.
Doug,
The interior space between the inner and outer skins on a '72 is between 1 1/2" and 1 3/4". So, 3/4" or 1" long screws will work just fine. For shelves and and stuff like that, I'd go with a #10 screw. It'll have a bit more holding power than a #8. I'd use a lock washer or something like loctite on the threads to help ensure they don't loosen up going down the road.
Chris
Old 12-31-2010, 09:34 AM   #6
nmbosa's Avatar
Nowhere , Washington
Brian, Chris has got you covered on the use of screws. I think he's right and it should work fine as long as you seal it up well.
I also have an Atwood 10 gallon water heater though, and I'll give you the heads up that it barely fits underneath the bed framing. In fact, I had to trim some of my bed framing to fit around the water heater. One problem you will notice during the install is that because the trailer's wall is angled in towards the belly, the water heater cannot sit quite flat on the floor. It will need to be shimmed up just a bit at the rear, which leaves even less room under the bed framing. Bottom line - it will fit, but it takes a fair amount of modifications.
One other suggestion that I know Frank has been using recently. If you can find some c-channel that fits inside the wall cavity, it is good to frame in around the water heater. The added structure provides for a much stronger installation of that water heater in the wall and would probably be especially helpful since you are using screws for the patch.
Norm
Norm and Mary
blog: Captain Wilson's Overlander
nmbosa is offline   Reply With Quote
Old 12-31-2010, 09:48 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Olympic rivets can be ordered and delivered pretty quickly, if it is not critical that you finish the job this weekend. Pop rivets a second choice.
I don't know the correct term, but if you use a different metal, such as stainless steel, aren't you inviting electrolysis corrosion to the aluminum shell?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 12-31-2010, 09:50 AM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I used pop rivets on my last airstream, then silver colored gutter sealant to fill the holes, looked fine to me anyway.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 12-31-2010, 10:52 AM   #9
pbearsailor's Avatar
Port Hadlock , Washington
Norm
Just got through doing this on mine and it really helps the structure. Virtually any scrap aluminum you've got lying around can be bent into C channel, even without a brake. Couple of pieces of wood, some clamps, and a mallet will make C channel that's just fine for these short runs.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-31-2010, 11:44 AM   #10
1963 28' Ambassador
Northern VT , Vermont
I used Stainless phillips head screws on both the water heater & furnace panels. #8s on the furnace & #10s on the w/heater due to the oversized holes. If the panels ever must come off its easier. Was worried about vibration & loose screws, used thin butyl tape to seal at a very warm temp. Sealed, neat and locks the screws. C or angle chanel around the inside strengtens the flimsy .032 panel, strengthens the connection & removes any sigh of warps around the screw holes.
putback is offline   Reply With Quote
Old 12-31-2010, 12:31 PM   #11
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Stainless should not cause electrolisis. Sal.
noreen&sal is offline   Reply With Quote
Old 01-01-2011, 02:07 PM   #12
Ready-to-Travel
pmclemore's Avatar
My concern was about the corrosion that occurs whenever dissimilar metals touch.
Pat
AIR 3987
TAC VA-2
WBCCI 4596
Old 01-01-2011, 02:21 PM   #13
Lothlorian's Avatar
Norm:
I just realized today that I am going to have to make modification to make the hot water heater fit. I have the aluminum angle iron fitted around the hot water heater for support. I will have to raise the bed frame off the ground a little but I think it will work. I am all ready to go with finishing the water except the weather is not cooperating. I still have not made the decesion with either screws or rivets.
Brian
Brian & Adrienne
Old 01-01-2011, 02:43 PM   #14
batman's Avatar
1964 22' Safari
modesto , California
Brian, stainless Steel and aluminum are very reactive as dissimilar metals. Not much issue under perfectly dry conditions. However just add a little salt mist or rain, wham. Galvanic reaction is documented on a lot of web sites. I believe there are a few here in this forum. I think you should stick to aluminum rivets.
batman is offline   Reply With Quote
Old 03-01-2011, 10:57 AM   #15
moab , Utah
I have a Boles Aero and I've replaced all the old rusted galvanized screws around the window and door frames with S/S screws. Even with the old steel screws there was no reactive metal damage. I would think S/S would be better.
eddiemoab is offline   Reply With Quote
Old 03-02-2011, 04:16 AM   #16
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Hi Brian;
There are issues with using self tapping SS screws in aluminum sheeting. Galvanic corrosion is one of them, but not the most critical. Pending the grade of SS, this can be minimized to a negligent rate. The problem is in number of threads per inch on a screw, and thickness of aluminum sheeting. With 0.035" thick aluminum you only get a half threads worth of bite which is usually further pre stressed by over tightening the screw. Second and most important is the issue of flex and vibrations in the trailer while on the road. The very minuscule grip gets even further pre stressed to the point where screws loosen up and eventually fall out. The guy following you finds them later in his tires.
Standard pop rivet is better than a sheet metal screw. While grip contact area is much greater that that of a sheet metal screws, you may encounter other issues.
You will contend with a hole in the head of the rivet for one. Secondly, pop rivet pin often tends to break right by the head of the draw pin, thus allowing head of the pin to fall out. This is most common when selecting too short of grip range. Eventually, in this situation as the rivet loosens up with time they begin to leak.
The Olympic Rivet is designed to offer most support when it comes to sheet metal and it should be used exclusively in such applications. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-02-2011, 05:12 AM   #17
Lothlorian's Avatar
Boat Dock:
Thanks for the info. I went and bought the Olympic rivets. Job is done and looks good. I know somebody who has the rivet shaver and they will let my borrow it.
Brian
Brian & Adrienne
Old 03-03-2011, 07:23 AM   #18
1988 25' Excella
Trumbull , Connecticut
Blind Pop Rivets
[There are pop rivets that have the end sealed so that it can't leak through.They can be used on gutters or anywhere there is a leakage possibility. You would still have to put something in the outside hole where the mandrel broke on installation but it would be strictly for cosmetic purposes.
Regards nm1oqrz
Chris[/QUOTE]
nm1oqrz is offline   Reply With Quote
Old 03-03-2011, 07:32 AM   #19
1988 25' Excella
There are pop rivets that have the end sealed so they can't leak through. They are used on gutters alot. You will stil have to put something in the outside hole where the mandrel broke off during installation but it is strictly for cosmetic purposes
Regards nm1oqrz
Old 03-03-2011, 07:50 AM   #20
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
The Stainless screws would probably outlast you.However,what I have done is to spray paint the threads and bottom of head with silver paint .Any overspray on the top of head can be removed with thinner when installed.
I will be modifying my heat shield on my 65 too soon,so post so pics of your progress.
bwaysteve is offline   Reply With Quote
Replacing Steel Wheels with Aluminum Daystreamin Wheels, Hubs & Bearings 8 02-03-2011 11:27 AM
Need help removing rivets. Breadbug Windows & Screens 16 01-19-2011 08:11 PM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
aluminum or steel rayandre LP Gas, Piping, Tanks & Regulators 3 01-01-2011 11:55 AM
