09-16-2014, 03:24 PM
Anchorage
, Alaska
Refurbish the 'Airstream' Placard
Is there a thread on how to refurbish the Airstream placard for a 196X ?
09-16-2014, 03:29 PM
1968 17' Caravel
Battle Ground
The PO of my trailer repainted ours by hand, but over the years the paint has faded and worn off again. I think when I get tired of looking at it, I will go with this:
1960s Airstream Plate
Stephanie
09-16-2014, 03:37 PM
Anchorage
, Alaska
Wow, was it blue ?
For some reason I was thinking red ?!?!?
09-16-2014, 03:54 PM
1962 24' Tradewind
Buffalo
, Wyoming
I did mine this last spring. Replacing would have been easier, but it's buck rivited on and I didn't want to go back with pop rivits.
I polished the whole thing. Then lightly sanded the background with about 400 grit sandpaper. I masked the entire thing with clear packing tape and cut around the letters with an X-acto knife, then peeled away everything that was supposed to be blue. I used Rustoleum Sail Blue spray paint. It seems to match the Airstream color really well. I masked the trailer to about 3 feet beyond the plackard, but got overspray beyond that. I should have masked better. The packing tape didn't seal well around the rivets, so there was paint under the tape. I had to clean that off. It was kind of a pain. So mask extra well around the rivets.
I made a mistake when I did the model sign by the door. The paint says to recoat within one hour or after 48 hours. I didn't read that and came back the next day to recoat. The paint crinkled up badly. I had to clean it all off and start over again. It was quite a mess.
09-22-2014, 05:43 PM
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs
, PA
Check out a member's thread on her 1963 Overlander. Her screen name is Reinergirl. She does something similar to what you have done. I am inspired by the work she's done on her AS. I am going to try to do this on my 1962 Safari International. I have had success with using Olympic rivets when doing work where I cannot buck rivet. Looks somewhat similar to buck riveting. When I took my 1976 Safari apart, I found that 1/2 of the shell was buck riveted and the other half was Olympic riveted!
Vintage Trailer Supply has just received new 60's Airstream nameplates.
09-22-2014, 05:52 PM
Hollis
, New Hampshire
Thanks Surfpod
My threads here, starting with post 44.
http://www.airforums.com/forums/f109...ml#post1110414
09-22-2014, 06:00 PM
1968 24' Tradewind
Oxford,
, Mississippi
I left mine in place and used clear contact paper to cover the placard after I had cleaned it. I cut out the area with a new blade in my exacto knife leaving the letters covered. I use Krylon paint in a blue that closely matches the original color. I don't remember the exact name but it is obvious which "blue" it is when you go to the store. It has been 4 years and mine still looks good. It would have been a little easier had I taken them off the trailer but I did not want to risk a leak.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
09-22-2014, 06:01 PM
1968 17' Caravel
Battle Ground
That is some impressive results! Hmmm, I already have a can of Ford Blue in the shop, maybe this is a winter project I should tackle?
Stephanie
09-22-2014, 07:11 PM
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana
, Pennsylvania
Badge Refinishing
I'm not sure if this would work for you but it might. I removed the badges off of our "78" Ambassador to make them more attractive. I started by stripping with Citrus Strip and rubbing letters and frame with fine scratch pad. Then I polished with 3" cotton wheel. Once this was done I sprayed with Rustoleum "Sail Blue", let sit for 15 minutes and then wipe the letters and frame with lacquer thinner. What a difference.
Indiana, PA
TAC PA-5
WBCCI 4871
09-22-2014, 07:48 PM
Loganville
You can buy a rubber wheel for your power drill. It looks and feels like a pencil eraser. It works awesome. It takes off decals and paint with no left over scratches.
Brian
Brian & Adrienne
09-22-2014, 08:02 PM
1960 28' Ambassador
1998 25' Safari
Avonton
http://www.airforums.com/forums/f4/r...ml#post1444951
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
10-08-2014, 11:57 PM
Anchorage
, Alaska
Did the door placard also have blue background ?
10-12-2014, 04:07 PM
Foothill Ranch
On the Motor Homes, these badges are cast aluminum...
As such, they never polish up well, or even retain the polish long.
I had tried polishing after rustoleum satin black, but it did not last or look good after 8 months in the CA sun.
I was told Powdercoating was more durable, so it was time to learn how.
I bought an Eastwood Powdergun and found a used outcast double oven off CL for free!
Test pieces at the ready...
Sandblasted them clean.
Heated them in the oven to 550F to outgas the casting and clean ready for coating.
Hung, and ready for powder..
Here we go..
Brushed off the areas that will be highlighted before it went in the oven..
This makes it a lot easier to finish them later, as the powdercoat is darned tough!
You can see how thick the powdercoat is.
Into the oven they go at 400 to flow out and cure.
After curing they looked like this.
After, the top was sanded with 180 grit sandpaper, it looked like this..
After clearcoating with clear powdercoat they are done..
10-14-2014, 05:12 AM
1973 25' Tradewind
1962 22' Safari
Augusta
Hey Keyair - you are a river master. Did not know that powder coating worked with aluminum. Great look on refurbishing the logos. I've been wanting to try powder coating some small pieces. Looks like I'm now in the market for a powder coating kit - off to eBay.
ps - I to have an old oven in the back of the shop!
10-14-2014, 11:18 AM
Foothill Ranch
Thanks, just trying to give some solutions to this badge finishing problem!
Looks like I messed up with the link to the last image...
Should have been this one.
Powdercoating is kinda fun, and very different to paint.
That badge blue should be easy to find in powder, and a metallic version would look really cool... if not totally original...
Something like this...
Hotcoat Powder Metallic Blue
FYI, I resecured my badges with screws, so I can remove them for skin polishing when it needs a touchup.
Yes, Aluminum is VERY good to powdercoat...
Here are some other Aluminum "Test Pieces" I have done...
Cast Aluminum Alfa Romeo valve covers..
And Airstream stuff I am working on...
Pair of Mickey Thompson cast aluminum valve covers destined for the 454 in the Motorhome.
These were ugly and corroded/stained... required some unrequired holes welded shut too...
End result.
This week I am finishing off one of the cast headlamp covers for the motorhome.
They were "Furry" with corrosion, which is the same issue I had with the badges.
Had to sandblast them a lot to get them ready... so maybe add a media blasting cabinet to you wish list... I LOVE having useful tools in my garage... got mine of CL for $100... just needed some TLC..
Coated with gloss black powder and ready to be cured.
Done, but still working to get the brush finish consistent on the corners of this complex casting before I put the topcoat of clear powder on.
10-14-2014, 11:23 AM
1968 17' Caravel
Battle Ground
Thank you so much for posting the step by step powdercoating process! I have been considering trying this myself. In addition to the Airstream, I have a classic Mustang that has a lot of bits and pieces that could use the powdercoating treatment. I definitly need to get into that!
Stephanie
10-14-2014, 02:08 PM
Foothill Ranch
Pleased to help!
Couple of pointers...
You cannot use your food oven... you will not get away with it... the cook will know. Even tho they say is more environmentally friendly than VOC paint, its a bit smelly when curing.
The powder uses static to cling to the part... and so its easy to knock it off, or rub it while transferring to the oven... that has been my biggest issue!
Once its flowed out(400f for 10 mins), and cured(a further 20 mins at 375) it is incredibly tough... I messed up a small steel part(about 2"x 3"), and it took me about 2 hours with aggressive aluminum oxide in my blaster to strip it off!
10-14-2014, 04:36 PM
Wildwood
So how much and where do we send our badges to get done? The cook would not only know if I used the food oven but also if I went out and bought everything to do the 5 badges!
Dave and Felicia
10-14-2014, 05:33 PM
Foothill Ranch
Dave... You are a powdercoating stalker.... ROFL
