06-24-2018, 02:07 PM
mweberg
2018 23' Flying Cloud
Scottsdale
White wire in battery box?
In the battery box of my 2018 Flying Cloud 23FB there is a white wire that is not connected to anything? The wire looks to be about a 10 gauge wire with a round terminal connector crimped on the end. Does anyone know where this wire should be connected? The dealer who is in another state replaced the second battery, but did not hookup this wire.
06-24-2018, 02:17 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Weird as it may seem, white is likely ground / negative. That would suggest it goes on the negative terminal of the battery. Best not to guess. Trace it out to where ever it originates ( the jack maybe or a solar adapter ) and then hook it up. based on the wiring diagram for that device.
06-25-2018, 07:42 AM
mweberg
Scottsdale
Thanks Bob for your input. I will try to trace it back. My guess is that it is to a solar panel option that I do not have. Would you recommend getting a solar panel to keep the batteries charged or just monitor the voltage and use a battery charger, if needed? Marlys
06-25-2018, 08:51 AM
Princeton
, New Jersey
The brake brake-away switch is normally wired directly to the batteries. Try tracing in that direction.
If it is the brake-away switch i would never go back to that dealer for anything other than direction to a different dealer.
2004 Excursion 4x4
06-25-2018, 09:05 AM
LEV ZEPPELIN
2004 19' International CCD
Chicago
The electric jack wire????
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
06-25-2018, 09:26 AM
Tampa
I have a 2017 FC and don't have a white wire.
The Zamp connector is a pair of black wires to the plug outside the battery box, while the jack is a black wire with a yellow crimp connector.
The breakaway switch, at least for me, is not in the battery box. I believe it goes from a terminal strip inside to the blue wire in the 7-pin. (which is why any battery box disconnect must be "ON" when towing.)
Perhaps the dealer didn't connect it because he didn't recognize it either.
I'd probably tape it over and tuck it aside so it wouldn't accidentally find a terminal before you discover it's purpose.
06-25-2018, 09:30 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
One way to figure it out is to go around trying this or that. The gizmo that does not work is the one that goes to the white wire . If everything works then your guess about the un-used solar setup is probably correct.
If you store the trailer in a sunny area, even a modest solar setup will do a fine job keeping the batteries topped up. We stored outdoors for a while and it was a great thing. We now store indoors and .... not so much .
The problem is that the batteries will likely die in a week or two due to parasitic loads in the trailer. Running back and forth with the battery charger can be a bit of a pain. A *lot* depends on exactly what you do and how you are set up.
Solar while camping is a similar sort of thing. If you camp in the shade and it rains a lot ... not a big benefit. If you are in the part of the country where both rain and shade are a scarce item ... much more useful.
06-25-2018, 10:59 AM
Mad Scientist
2017 23' Flying Cloud
CULPEPER
, Virginia
I have a 2017 Flying Cloud 23FB- and I don't have a white wire in the box. However, according to the schematics in the owner's manual ( pg 86 in my manual), there should be a 10 Ga white wire from the 7 pin trailer plug (pin 4) to the ground buss inside the trailer under the front LHS of the bed- perhaps they forgot to route that wire and instead just planned on connecting it to the battery negative inside the box. A little sleuthing with an ohmmeter should determine if they left out this VERY necessary wire. All grounds on the 12 VDC side of the AS are white.
Sam
KE5IRZ
06-25-2018, 11:43 AM
1995 21' Sovereign
Petaluma
My break away switch and electric jack are both grounded by touching the frame. We have a large white wire that is connected to the battery which is for our solar panel.
06-25-2018, 01:57 PM
The Aluminum Tent 3
2014 23' Flying Cloud
Park City
, Utah
How about a couple photos, showing where it's coming from. That might help us help you figure it out.
06-25-2018, 02:47 PM
mweberg
Scottsdale
Thank you all for responding. I will try to trace it back and take a couple of pix as well. My hunch is that it is for the solar panels which I do not have, (yet). Marlys
06-26-2018, 06:41 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
No matter what it is ... it's odd. If your solar was an after market install, that may be what's going on. Factory solar does not generally result in a white wire hanging loose anywhere
06-28-2018, 09:27 AM
Santa Rosa
Hi mweberg, I have a 2018 25' Cloud with a dual AC (50 amp) and solar kit. I just replaced my replaced my batteries under warranty. I believe have the white wire in question. Mine originates driver-side, from a "bundle" of 3 wires; black, red and white, all are nearly the same heavy gauge. My white wire attaches to the negative post on the passenger-side battery. I can't figure out how to add the picture I took.
-Sean-
07-02-2018, 01:50 PM
mweberg
Scottsdale
Thanks Sean! I've been kind of thinking that the white wire has something to do with the solar panels and this is why the dealer did not have it hooked up. Thank you for your input!
On another topic, does your water pump effectively pump out water from your fresh water tank? Or, does it spit out lots of air and consequently have very little water pressure? I'm curious to know how your 25 ft Cloud water pump works compared to the one in my 23 ft?
Marlys
07-02-2018, 10:41 PM
Santa Rosa
I haven't experienced any water pump issues. I'm definitely not the expert here, but it sounds more like air in your lines. I recall reading a thread somewhere here detailing how to purge air from the lines. If you have a loose connection, or one without teflon tape, maybe it's pulling air with water. Try posting your issue in the section covering water lines etc.
-Sean-
