Originally Posted by CoorsLite
Once again Uncle Bob you have provided valuable guidance. Thanks very much.
You may have saved me an expensive battery (my Touareg TDI has an AGM battery with an imbedded chip), not to mention my new AS batteries (two Group 27’s).
My spidy sense told me that rapid charging with jumper cables may not be a good thing. You have just confirmed that. So why did I consider booster cables?
My Touareg has a 10AWG wire that leads to the 7Pin charging circuit. My worry was that heavy charging may overwhelm the 7Pin circuit, as I have at least a 150 Amp alternator. Hence the booster-cable approach. I have recently learned that the Touareg manages the 7Pin circuit to ensure correct current and if all else fails it is fused.
All of this points to alternative charging methods described well on the forum - Solar (I plan to install) and a generator (still considering but may be inevitable).
Thanks again.
Hi
No problem, we all thrash through this stuff ....
Simple way to look at it:
If both the TT and TV batteries are at the same voltage, no current will flow.
If they are at different voltages, the current is limited by the resistance.
Wire resistance is length times ohms per foot.
A 10 gauge wire is pretty small in terms of charging a battery. By the time you run all the way to the back of the SUV and then loop around in the trailer .... lots of resistance.
The wire on the 7 pin is there mainly to keep things topped up while rolling down the road.
