Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 05-07-2002, 07:11 AM   #1
rjones1138's Avatar
Send a message via AIM to rjones1138
Question Univolt Low Buzzing Noise
We're brand new Airstream owners. We just got our 81 Excella 2 set up in the campground. We are noticing a low buzzing noise in the front of the camper. After a long time searching, I figured out that it is coming from the Univolt. The buzzing is constant and low pitched, not very loud. Is this normal? Thanks for the help.
Ric Jones
rjones@ptd.net
rjones1138 is offline   Reply With Quote
Old 05-07-2002, 08:18 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
When you are plugged in to shore power, there is a low level buzz that is normal from my experience. When I plug in this confirms my connection..and continues all the time I am connected.
Old 05-07-2002, 11:57 AM   #3
Jim W's Avatar
I replaced my univolt a couple of years ago because it stopped working. The new one doesn't make any where near as much noise as the old one did, but you can still hear it. You need to worry when you can't hear it. That was when I had to get a new one.
SF CA area
77/31' Airstream
99/Suburban/454/4.10
#18248
Jim W is offline   Reply With Quote
Old 05-07-2002, 01:54 PM   #4
Univolt [converter] changes
Our univolt system is changed from the factory configuration. An aluminium box was fabricated for the univolt. A hole was made to allow the unit to hang from floor under trailer. This location allows more use of floor space, less transformer noise, and the unit operates cooler. The recessed box has a aluminium cover that prevents anything from entering box. The converter is controlled by a standard wall switch near the unit. All the dc voltage used in trailer can be sourced via the converter, the trailer batteries or power from the tow vehicle batteries. The trailer batteries can be used individually or together. The remote location of the converter reduces the output hummmmm considerably. The batteries are connected to a permanently installed digital voltmeter. A fully charged battery will indicate 12.6 on a digital meter. Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 05-07-2002, 01:59 PM   #5
Floor mounted converter Pic
Converter box in floor Frank
Name:	converter box in floor.jpg
Old 05-07-2002, 02:44 PM   #6
tenrsingr's Avatar
I am curious if my post even registered.... Anyway..
Jim,
Is your new converter an old univolt type or is it a newer solid state type?
Steve_in_Savannah
'94. 29' Excella Classic
2001 5.4L Ford F150 Lariat Super Cab
wife & 2 boys
tenrsingr is offline   Reply With Quote
Old 05-07-2002, 02:49 PM   #7
tenrsingr's Avatar
Mine is really loud now. I had to buy a fan to drown out the humming...
Do the newer models protect the battery also??
Steve
Steve_in_Savannah
wife & 2 boys
Old 05-07-2002, 04:45 PM   #8
Airstream Driver
PeterH-350LE's Avatar
1994 30' Excella
1992 35' Airstream 350
Images: 49
This is a nice little converter.
Inteli-Power 9100 55Amp
The additional charge wizard takes good care of your batteries.
No humming or buzzing, just the occasional cooling fan kicking in.
PeterH-350LE is offline   Reply With Quote
Old 05-07-2002, 06:19 PM   #9
Jim W's Avatar
I think my new converter is not the replacement univolt. From what I read, it has its own battery charging system that keeps the battery charged, but won't ever over charge it ( they say). When they finished the hook up, there isn't any amps reading on the meter in the control panel, which I liked. I think the unit that Inland RV ( Andy ) has on his web site is a closer to the one that came out of my unit. That unit lasted about 23 years, so I can't complain. The buzzing was louder than the new one & I think the battery charger is much better than the one in the old unit.
SF CA area
77/31' Airstream
#18248
Old 10-29-2002, 06:05 PM   #10
Larry Brown's Avatar
Question ok?
Ok? how the ------------ are ya susposed to remove the box that is covered with carpet that covers the univolt I can't seem to find any screws or flanges are anything except for a million staples (furniture type) under the carpet. any ideas would be helpfull.
Larry Brown is offline   Reply With Quote
Old 10-29-2002, 07:06 PM   #11
Airstream Driver
1994 30' Excella
Images: 49
Larry,
don't pull all the carpet of the box. It is screwed to the floor and to side via metal flanges. You may have to remove the decorative piece of vinyl to get to the screws.
PM or email me if you wish.
AIR #13
Old 02-25-2003, 07:22 PM   #12
Chas's Avatar
Images: 22
what a deal!
Pulled out ole Mister Buzzy "Univolt" this last weekend and am awaiting my new 60 amp Intelli-Power converter, yes bigger than Peter's, with the "Charge Wizard". I was going to put a switch on it to turn it off so I could sleep but said the heck with it, it will be of better use as a boat anchor. I had an Intelli-Power in my Argosy and they are much quieter, all you hear is a little fan noise occasionally.
By the way, anyone want to guess how much a Univolt weighs? A correct guess will entitle you to a free working Univolt, a little noisy, but servicable. (shipping excluded, of course)
Chas
Chas is offline   Reply With Quote
Old 02-25-2003, 07:33 PM   #13
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
58LBS
And if I am right I don't want it!!!!!!!!!
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 02-25-2003, 07:36 PM   #14
Chas's Avatar
Images: 22
Too high, mine is a 55 amp with the internal fuse block and if any of you wanna get closer, heck I'll even spot any of you 5 lbs. either way!
(I edited it and increased it to 5 lbs.)
Chas
Old 02-26-2003, 11:12 AM   #15
Chas's Avatar
Images: 22
39 lbs!!
O.K. then,
Newkid is the winner by default!
Your address please? I will ship it C.O.D. for the freight.
Chas
Old 03-01-2003, 10:09 AM   #16
Just a member
1978 28' Argosy 28
Lutz , Florida
Images: 21
Chas,
Thanks, but no thanks!
I bet you could get at least $25.00 for it on ebay! Just rememember it is "rare" and "original" and they don't make them like this anymore! A new one could cost you 200.00 or more at the local RV dealer!
With tongue firmly planted in cheek................
Brett G
Old 03-01-2003, 07:47 PM   #17
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i sold one last month for $75.00 . was out of my motor home. replaced it with 9160 with charge wizard.
no thanks i dont want it either.
al
wb13798 is offline   Reply With Quote
Old 03-01-2003, 08:42 PM   #18
Chas's Avatar
Images: 22
Ebay? Excellant idea!!,
I actually do have a box where I keep all the outdated and non-working original parts, who knows, someday they may be worth some bucks!! Actually my Airstream dealer kinda wants it for parts, guess it may still have some life in it.
Got the new 60 amp Intelli-Power installed today. Tell me something, my old univolt weighed 39 lbs and the Intelli-Power weighs about 5 lbs., what gives?? Old school, new school?
Chas
Old 03-02-2003, 07:16 AM   #19
Just a member
1978 28' Argosy 28
Lutz , Florida
Images: 21
34 LB weight reduction! cool, now you can carry cases of Adult beverages and never worry if you are in a dry county or not!
Brett G
Old 07-04-2003, 05:43 AM   #20
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
UniVolt
Ok, tell me what I am missing here. I see many posts talking about Univolt systems overcharging batteries, so I went to my trusty owners manual for my '78 Excella 500 and read...
"When your Airstream is hooked up to 120 volt A.C. the Univolt System automatically charges the trailer battery and, if it is hooked up, your automobile battery as well. The speed and degree of charge depends on how much power is used for lights and appliances, as only the surplus goes to charging the battery.
... Whenever possible, use the automatic built-in charger of the Univolt System for charging. The charging circuit automatically controls the current, reducing it as the battery increases in charge."
From the sound of this, the Univolt System handles it all. Mine makes a slight buzzing noise, which I understand is normal. Did older Univolt Systems not have a charging circuit that limited the charge?
Vic
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
https://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 4 08-07-2020 10:13 AM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
Removing Old Univolt & Installing New Intellipower 9160 montanaandy Electrical - Systems, Generators, Batteries & Solar 3 07-15-2003 11:08 AM
Univolt stop running and start later brunoffrance Electrical - Systems, Generators, Batteries & Solar 6 07-04-2003 12:33 PM
univolt III wiring McGill Electrical - Systems, Generators, Batteries & Solar 0 07-05-2002 08:26 PM
