Maintaining Ducted Air Filters
The ducted air system has filters that need to be maintained regularly. Their performance can be improved to help keep your interior air clean.
To remove the filter, pull down on the end of the vent with your fingertips. It will be tight, but it should come out. The vent and foam filter will be dirty, so wash them in soapy water. To improve the filter, I used a material called Allertech VentGuard, and cut the new filter using the old filter as a pattern. Replace the vent cover, making sure that the filter stays in place. The new filters will collect a lot of dust and dirt, so be sure to check and replace them with new ones on a schedule, at least once a year.
Some photos showing the process are attached:
Enjoy the clean air!
