09-02-2013, 01:54 PM
2012 25' International
Austin
Help! No Electrical Power inside 2012 A/S Int.
Have a 30 amp plugged into my A/S the power light indicator is on but everything is dead inside. Breakers are on. What am I missing?
Thanks in advance!
Tom in Austin
09-02-2013, 01:56 PM
1974 Argosy 20
Kooskia
, Idaho
Is the use/store switch in the Use position?
09-02-2013, 02:06 PM
Austin
Yes, it is in USE position.
09-02-2013, 02:12 PM
2019 30' Classic
Byhalia
, Mississippi
If you haven't already, manually flip all breakers to the off position, then return them to on and keep your fingers crossed.
Greg
09-02-2013, 02:16 PM
Austin
No joy. Reset breakers. Could this be a blown inverter?
09-02-2013, 02:19 PM
Free Range Human
2012 25' FB Flying Cloud
Haines
Your use switch doesn't need to be on when connected to 30 amp. My bet is you have a tripped breaker because of the source. If you have a surge protecter, use it, and make sure it trips when you test it.
But first, an obvious question... Is the source 30 amp on?
Recycle the breakers at the source, and in the AS.
09-02-2013, 02:25 PM
Free Range Human
Haines
That would be a converter... AC-> DC
With external off, do you have DC when the use switch is on?
I sent a PM with my cell if you want to talk.
09-02-2013, 02:53 PM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
Does the microwave, TV or air conditioner work?
These are separate from the battery/convertor circuits and will confirm you have 120 volts into the trailer.
Regards,
JD
Jeff & Cindy
09-02-2013, 02:57 PM
Austin
No power to anything inside.
09-02-2013, 02:59 PM
Jay
, Oklahoma
Breaker on the post you are plugged into?
Some folks always turn the breakers off at the post when unplugging their shoreline.
JD
Jeff & Cindy
09-02-2013, 03:18 PM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
Transfer switch problem? You have 2 elec inlets on the trailer - have you tried both? If not suggest you do so. The transfer switch problem has been covered in a number of other threads which you should be able to find with a search.
09-02-2013, 03:27 PM
2012 25' FB International
Trent Woods
Agree that it has all of the symptoms of a transfer switch problem. Your LED on the cord will be on but you will not have power to the breakers and converter.
Larry
09-02-2013, 03:34 PM
Austin
Nothing works. No micro, battery power to jack, TV or Air Conditioner.
09-02-2013, 03:36 PM
Austin
Will try front plug on trailer.
09-02-2013, 03:47 PM
Austin
Genius award to transfer issue!
Didn't have enough reach to try the 30 amp so put on the 110 connector and hooked to front plug-in and immediate power inside.
09-02-2013, 03:49 PM
Jay
, Oklahoma
Good call.
My '09 just has one, and I always miss that.
Glad it is working. That is a known issue, and warranty will cover it.
Regards,
JD
Jeff & Cindy
09-02-2013, 03:54 PM
Austin
These little bugs are the worst thing and the best about Airstream! Thanks to everyone for helping me! Austin, Texas has a cold beverage on me waiting for my Airstream instructors!!!
Thank you,
Tom
09-02-2013, 04:18 PM
Free Range Human
Haines
Cool beans and good news!!! You might consider picking up a 25 foot, 30 amp extension. Mine has come in handy a time or two.
I agree, genius award to AL - KG4U.
Are you getting DC to the batteries now, so that the jack is working???
09-02-2013, 04:22 PM
1999 34' Excella
Hillsboro
Make sure you see the transfer switch replacement. There apparently have been several failing. In one guys AS repair to main wiring was needed.
Peace and Blessings..
Channing
WBCCI# 30676
09-02-2013, 05:04 PM
Austin
No sooner did I step in the house, the front 110 plug apparently blew (blue LED light on front plug-in was out). Decided to try the rear again. Plugged the rear into the 30 amp and A/C is working etc.
Seems pretty finicky. The electrician who installed the 30 amp is coming tomorrow and will see if he's got an idea?
