Old 03-05-2021, 08:32 PM   #1
1962 24' Tradewind
Quakertown , Pennsylvania
'62 Rewire
Hey all, We are getting close to wiring. I've done a good bit of reading and I'm thinking of going with Marine grade 10AWG Ancor Marine Grade Duplex for all my runs to my 12v stuff, (12AWG for short runs.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Then running 12AWG Ancor Marine Grade Duplex for all my 110.
https://www.amazon.com/gp/product/B0...KYWQUJT0&psc=1
Already have 7 strand trailer cable running front to back for all the trailer lights etc.
Any help or tips diagrams etc. are appreciated!
62rosie is offline   Reply With Quote
Old 03-05-2021, 11:06 PM   #2
57Vintage's Avatar
1958 26' Overlander
Battle Ground , Washington
Images: 22
Depending on what loads are on each circuit should determine the wire size. You may not need 10 awg on all your 12 volt runs. I assume you know heavier guage is needed for the main circuits: batteries/shore power/main breakers. I put together the following list in preparation for wiring our Overlander. Hope it helps.
ELECTRONIC CIRCUITS.pdf
I do agree with the decision to use marine grade wire. I used it through out for all circuits.
Harold & Rebecca
Our thread:
https://www.airforums.com/forums/f97...er-172124.html
57Vintage is offline   Reply With Quote
Old 03-06-2021, 04:36 PM   #3
1962 24' Tradewind
Thanks you!
Old 03-06-2021, 04:57 PM   #4
mikextr's Avatar
1967 26' Overlander
Bugtussle , Oklahoma
You can do both the 120 and 12v with 12awg. That Anchor Marine grade stranded is thick and tough to pull through existing holes. Get a stepper bit and plenty of plastic insulators for the holes in the ribs.
mikextr is offline   Reply With Quote
230v to 120v stepdown transformer or rewire? finn2020 Batteries, Univolts, Converters & Inverters 9 04-05-2007 07:09 AM
1967 Overlander 110v rewire TNBUBBA Electrical - Systems, Generators, Batteries & Solar 1 10-09-2006 10:17 AM
54 safari rewire durans54 Electrical - Systems, Generators, Batteries & Solar 2 01-18-2005 03:52 PM
Should I just rewire it? 63air Electrical - Systems, Generators, Batteries & Solar 5 08-29-2004 09:55 AM
Rewire with Copper McMullen 1965 - 1969 Overlander 4 11-18-2003 03:08 PM
