One more thing I thought of just now:
Make sure the building contractor installs a good quality vapor barrier beneath the garage slab. This is required by code for living spaces, but not for a garage.
If there is no vapor barrier more water vapor will come up through the slab from the earth than will come through the walls from the air. I'll bet ground water level where you live in FL is similar to where I live in Highlands County FL during winter, only a few feet below the surface.
Use 6 mill polyethene minimum. I like Stego products, but their materials are $$$.
Alan
