Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Overlander > 1965 - 1969 Overlander
Old 08-19-2017, 12:28 PM   #21
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Univolt is dead. Long live the Overlander.
Guess I will be buying a converter....soon. Thanks for all the tips. No fuse other than the panel fuses were ever found.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-19-2017, 01:55 PM   #22
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
If you go out and get a new converter, spend some quality time digging into this and that. There are some dirt cheap ( = avoid) models out there, some modest price / reasonable performance, and some very good units. Compared to the price of a pair of nice big AGM's, none of then are all that scary.
Old 08-19-2017, 02:31 PM   #23
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I have installed several Progressive Dynamics converters. The PD9245 is a good unit and quite economical. Very easy to replace the old unit with. Takes about 20 minutes to change out, and I use the old leeds from the univolt to the 12v breaker panel. Did have one fail this week after a month's use, and Progressive sent a replacement the same day. Good people to deal with. Ebay is a good place to purchase.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 08-20-2017, 06:10 AM   #24
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks for the tips. This will be the third one I have replaced in my Airstreams. They are relatively easy to install.
AIR #005
retired!
Old 08-03-2018, 03:19 PM   #25
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
replaced the converter with major help from Mike G a fellow streamer. everything worked.
AIR #005
retired!
Old 08-04-2018, 06:46 AM   #26
Half a Rivet Short
2022 Interstate 24X
Hi
While you are in "upgrade mode" at least consider a battery monitor. The BMV-712 is one option. There are *lots* of others ....
LED lighting retrofit for interior lights Westfalia Lights - Interior & Exterior 377 08-14-2023 10:04 PM
Track Lighting & Lighting Ideas ClassicRides Electrical - Systems, Generators, Batteries & Solar 15 05-19-2020 02:10 PM
Changing LED lighting to halogen lighting dreamstreem Electrical - Systems, Generators, Batteries & Solar 14 10-12-2011 06:42 AM
Interior 12 Volt Lighting - Juno Trak 12 flyfshr Electrical - Systems, Generators, Batteries & Solar 23 06-06-2006 06:55 PM
