Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 02-03-2006, 08:29 AM   #141
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Un-winterizing
Originally Posted by Gen Disarray
Give it another four short weeks and we will all be un-winterizing our coaches
4-weeks? Yesterday, that mean old groundhog in PA announced that we are due for at least 6 more weeks of winter! GRRRRRR!
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 10-18-2006, 04:29 PM   #142
1996 30' Excella
Burlington, Ont. Canada , Ontario, Canada
Excellent Tips folks, many thanks.
Easyriser is offline   Reply With Quote
Old 10-18-2006, 04:41 PM   #143
Frank S
peoria , Illinois
Hi jvandal--If PO used a lot of well water in the fresh water tank, you might just have mud, and possibly mold from un treated water in the drain, which IMO is to small in diameter to drain adequately.--Frank S
Frank S is offline   Reply With Quote
Old 10-27-2006, 05:06 PM   #144
firedog's Avatar
1992 29' Excella
JOY IN , Arizona
First Time Winterizing.
Thanks for all your imput.Its done and done right because of this fourm.My cost,33.50.fitting for air pressure 6.95 - rv anti freeze 8.00 - anti feeze valve kit 17.00 plus tax. done until- jan-2007 trip south.firedog.
wbcci ,#3510 NEU & 4cu https://fire1.smugmug.com
firedog is offline   Reply With Quote
Old 01-22-2009, 07:06 AM   #145
Whirlaway's Avatar
2008 27' Classic FB
Anytown , Massachusetts
Could someone describe the "exact" position of the bypass knobs when in BYPASS mode?
I am heading south and will be winterizing for the first time prior to returning. The manual says reverse knobs to bypass mode?
Currently the silver oval knobs are parrallel with the plastic tubing. I was told this is the "summer" run position.
When blowing out all the water, do the bypass knobs stay in the summer / run position - parrallel to the line?
THEN....
When all water is expelled from the lines, turn the knobs to the "bypass" mode.
Which I would believe means the knobs would be up/down forming a cross to the water line? All three (3) correct?
And then follow all the info of introducing the antifreeze at the pump location.
A clarifications on this would be very helpful...All three (3) knobs would be turned to an up and down/ cross position relative to the water line.
Thanks in advance.
Life Is Not A Dress Rehersal
It's okay to have too much fun
WBCCI #8701* TAC MA-1 * NEU UNIT
Gracie...A Liver & White GSP
Get busy livin', or get busy dyin'." - The Shawshank Redemption
Whirlaway is offline   Reply With Quote
Quicky Hints and Tips FrankR General Repair Forum 7 10-05-2012 10:09 PM
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 02:44 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 06:50 PM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 08:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
