Old 02-19-2022, 04:29 PM   #1
Barracuda's Avatar
1996 30' Excella
Jordan Falls , NS
Replacing plywood floor
Just found a section of plywood at the forward right hand side of my 1995 AS that is soaking wet, as I lifted the carpet to replace it with vinyl plank.
It looks like there has been a leak for some time as I managed to push a screwdriver right through. There is a section break in the plywood just aft of the damaged area, so I should be able to remove the for'd section.
My question is how easy is it to do this. I did note there were large countersunk screw/bolts, which I presume secure the plywood to the frame. Any advice would be much appreciated.
Barracuda is offline   Reply With Quote
Old 02-19-2022, 04:37 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
How big is the damage?
Old 02-19-2022, 04:49 PM   #3
Barracuda's Avatar
1996 30' Excella
Jordan Falls , NS
It's an area that extends maybe 6" in from the shell and maybe 3' long
Old 02-21-2022, 01:55 PM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
That is a fairly small area. Short of replacing the whole section there are 2 alterrnatives:
1. Cut out damaged area. Scab in a replacement piece of plywood (screw in a backing piece and then screw in the new piece to the backing piece.
2. If the old floor is still intact coat it with penetrating liquid epoxy such as Rot Doctor
replacing rear sheet of plywood pkmeaton Repairing/Replacing Floor &/or Frame 8 05-01-2017 08:07 PM
marine plywood vs plywood vs osb bweldon Repairing/Replacing Floor &/or Frame 35 07-13-2015 07:29 AM
Replacing Plywood Tank Base Smokin Camel Fresh Water Systems 7 09-09-2007 04:14 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 11:00 PM
replacing plywood floor with plastic imeynstein Repairing/Replacing Floor &/or Frame 2 04-01-2004 12:13 PM
