Been having some power problems with my 1988 325 AS MH.
So far the circuit breaker and another part of the power system have been replaced, but it looks like the converter is bad and might be the key to getting my power working again. But The manual does not show where it's located. We think it may be under the stove.
Probably under a bunk near a hidden AC outlet and the main DC fuse panel is within a few feet of it. But you never know. In my 1984 270 it was under the bunk just aft of the door
Robert, on your unit it is most likely under stove, behind the 12V fuse panel.
No need to remove the stove, you should be able to get to it from the front.
AIR #13
Decided since it looks like the stove is going have to be pulled might as well get a more modern fuse panel and move that to a location that can be easily accessed.
I have a diesel pusher on Freightliner chassis. Converter was in front of passenger seat behind a wood carpeted panel. I upgraded it to a 75amp converter from Camping World with a cooling fan. No problems since it was replaced.
