I may have to start a build thread. As I mentioned in a previous post, we came into possession of an '88 34' Limited over the weekend. I've determined the axles (all three) will need to be replaced as the arm is at a negative angle. I crawled under the trailer to look at what I needed to do and found that a PO had at some point put a jack under the frame in the area where the lower mount for the center axle shock is. (picture attached). My concern is that once I drop that axle and go to put the new one on I'm going to run into fitment problems. Can anyone verify? I'm hoping I'm just overthinking this. Thanks!
https://photos.app.goo.gl/rPcgCig2n7XZqdcCA
