03-12-2019, 03:21 PM
2017 Interstate Lounge Ext
Plano
Tire Balance - Steel Valve Stems
Starting to think it would have been better to just leave the tires and valves as is and just manually check tire pressure versus the work to get metal valve stems and TPMS.
Neither Mercedes place near me that works on sprinters would do the valve stems. Finally just went to a place near me that was a tire shop and said they work on RVs etc. with good reviews. Got the valve stems installed but didn’t have my TPMS caps with me (my fault). On way home lost a lug cap.
Once home, couldn’t install the TPMS caps on front tires (not enough clearance from rim. Installed and set up the rears. Kind of a pain to add/remove air but was happy to see the tire pressure on the remote monitor for the back wheels.
Knew the tires should be balanced with the caps but figured I could get to that once I got the lug replacement. Took a trip and lots of vibration from the front so now sitting at a Goodyear. Getting valve stem adjusted so can get caps on fronts and balance everything. The amount of weights they are putting on the exterior side of the rim is surprising and ugly. Asked about having the weight in the inside and tech said they wouldn’t stay put there. In the past had weights glued to rims on inside (bmw).
What a pain and now ugly look on these nice Alcoa rims but better than bouncing down the highway.
Sure would be nice if Mercedes and Airstream could include TPMS from the lot with metal stems already. My F150 has a much better system built in and not requiring caps or external monitor.
A bit frustrated...
03-12-2019, 03:35 PM
Plano
A couple pics.
Tech said he had to put weights on both inside and outside to get it to balance. Last place just had them on inside.
03-12-2019, 03:48 PM
Tampa
Call me crazy but I can't see how metal valve stems and caps change the balance.
Did you drive it and notice a change?
If it bothers you, there's always Centramatics.
03-12-2019, 04:19 PM
2013 Interstate Coach
Waterloo
, Iowa
Good to know about the ugly weights. I had been planning on installing TPMS at my next rotation, but may change my mine. Tried Centramatics on the back duals - no go. They fit but it was impossible to check pressure or add air. The oval holes is in the Centramatic and the oval holes in the rims lined up, but there was no space to insert a gauge or air chuck.
03-12-2019, 04:37 PM
Tampa
Your middle picture shows a ton of weight opposite the cap sensor. Assuming there's an equal amount inside the rim also, there's probably a pound of wheel weights offsetting a cap that weighs 0.54 oz.???
Either there's a big problem with the tires or the "tech" didn't know what he was doing. I vote #2.
03-12-2019, 08:05 PM
Plano
Yeah... it was very noticeable at the steering wheel. Lots of vibration and really felt like it was the fronts. It was only the metal stems on the front at that point through.
Will take it back to the original place once we get back home. Haven’t gotten up to highway speeds yet but it is driving a lot smoother today.
03-12-2019, 08:10 PM
Plano
Yeah... unless there is a dent in the rim. Some of these states need to spend some money on infrastructure (looking at you LA). There are some huge pot holes but with the tire size and running 71psi I would think my rims didn’t suffer any damage although probably loosened a ton of things on the inside of the AI.
Haven’t hit any curbs or bricks.
03-12-2019, 08:40 PM
2020 Classic 33
Box Elder
, South Dakota
Consider getting wheel balancers from Centramatic. That would be a cleaner way to have everything balanced. They are on the southwest side of Dallas so not that far away from you. Buy from them and the will install for free.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
03-12-2019, 09:04 PM
1994 34' Excella
Warren
, Manitoba
Install ceramic balance beads in the tire. Good tire shops will have the correct size of bag weight to install in your tires. Similar to centramatics in eliminating the balance problem and no ugly weights on the rims. You will need to install a filtered valve core, which usually comes with the bag of beads. Big rigs run these all the time.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
03-12-2019, 09:06 PM
2016 26' Flying Cloud
Southlake
A couple of observations. A balance can be done with weights on either one side (single plane or static) or both (dual plane or dynamic). There is no difference in the end result except on cars that are very lightweight or sensitive to imbalance (rear engine cars are one example).
Tire pressure monitors that I am familiar with come in a couple of flavors. All of the OEM and some aftermarket have everything inside the wheel/tire, including the battery and some of them either do not have replaceable batteries or you have the send them back to the manufacturer for batteries as often as every 2-5 years. Others have all the circuitry and battery in the external cap. The disadvantage to the external caps is that they can be stolen or damaged by hitting something and they are unsightly. There are two types of external caps. The flow thru and those that or not flow thru. You can adjust tire pressure on the flow thru without removing them but they are taller and make them more susceptible to damage.
I chose the TST that are not flow thru and it is a little irritating to remove them to adjust tire pressure. And if you are anal about the readings on the display and you want them to read exactly the same when cold, it will take several attempts and the tires must all be in a climate controlled building and either all or none in the sun. Catch my sarcasm?
I replace my batteries each Spring.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
03-13-2019, 06:21 AM
Plano
Thanks... I will look into that.
03-13-2019, 06:30 AM
Tampa
Yes, but the good outweighs the bad. If it's too irritating, take off the security caps, then you'll be able to unscrew them just like a valve cap. (unfortunately, so will everyone else.)
Yes, I'm not that anal. I think there's a slight difference in the cap transmitters.
If mine read 65 psi, I take that to mean they're not 55psi or 70 psi.
It's great to get in in the morning before the drive and see nothing has changed!
When I named mine I started what I thought logical; #1 on the driver's side front, then #2 on the curb side, etc. But the monitor reads them starting on the curb side, so I guess mine read 2, 1, 4, 3! Maybe someday I'll swap all the labels.
You still know which tire is being read.
03-13-2019, 06:31 AM
Plano
That is what I have as well... From this forum recommendation. I had a cigarette lighter air pump that I could set to 71lbs and let it chuck away but now it doesn’t work so I am using my full size air compressor but it doesn’t stop at a set pressure. So I use that in combination with a digital reader. Trying to get everything to match. Then you have to be pretty quick getting the TST caps on or you can lose 1/2 psi. Would prefer it built in...
With the frustration of the tire stuff yesterday it was awesome taking a crew of 7 to dinner at LuLus in Gulf Shores... the looks we get with these rigs makes me proud when they are all unloading, etc. Also had a family staring it down in the parking lot (perfect backing into single space) and after I said hello to him he asked “Is that there an Airstream on a Mercedes”. I have them a quick tour.
03-13-2019, 09:43 AM
Retired paddler
1993 29' Excella
Brighton
, Ontario
X 2 on the beads👍
Cathy and Hans
1993 Excella 29' w/Hensley
2011 GMC SIerra 2500HD SLT
03-13-2019, 10:54 AM
2014 Interstate Ext. Coach
fairfax station
, va
Maybe some other time
I really wanted TPMS and was always going to pull the trigger but stopped short.
I had balance issues and knew this would just complicate matters so I finally abandoned the idea.
I just check pressure often.
Alcoa, dually, Sprinter, Mercedes....there's a real talent, tool and knowledge gap in making the tires run right.
A tire shop really has to know their business and Mercedes ain't one of them.
This is what Mercedes is good for.
03-13-2019, 11:23 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Sounds like pulling the tires and installing the internal sensors would be the way to go for dual wheels. A better installation all around.
03-13-2019, 03:54 PM
Plano
Got out to the Van this morning and the inside passenger side tire was low. Apparently the cap wasn’t tightened enough. My little compressor that worked fine with the other stems no longer works with the metal stems.
Not sure if it isn’t getting deep enough on the stem but it won’t even pump... disconnect it and it pumps. I really liked this little guy. Set the desired psi and some minutes later it was done. I guess I will have to get the VRB thing that wachuko has... Air Compressors at gas stations are terrible. Had to go to 5 to get one that works.
03-17-2019, 06:19 PM
2010 Airstream Interstate
2010 22' Interstate
Lafayette
, Louisiana
My Aftermarket TPMS Solution
This is what I did for my aftermarket TPMS system, of course after this I ended up getting new tires and all new valve stems so I didn't have any balance issues.
The first extensions I used kept bending the valve stems or adding pressure on them so they ended up leaking or getting cut from the steel rim. I found these extensions on Ebay and other clips to secure them to the wheels so they didn't move.
From there I drilled some holes into the wheel covers with a washer and mounted the valve tips through the covers using the hardware that comes with them. This way they do not move at all so there is no unwanted pressure on the valve stems. The fronts are normal
03-20-2019, 01:21 PM
2005 39' Skydeck 390 SD
Hillsboro
Centramatic only available on the rear. I balance with ceramic beads work ok.
Peter
03-20-2019, 05:23 PM
2015 30' Flying Cloud
Port Sanilac
, Michigan
Valve stems
I’ve run 30,000 miles with Eez Tire Tms in original rubber valve stems. No issues.
