Sway Bar Removal Problem
I have searched the Airforum for information on HOW people installed the Hellwig Sway Bar, that is compatible with my 2017 AI Grand Tour EXT. I decided to take it to a shop that had the ability to at least get the back up high enough to work on it. PROBLEM: The generator interferes with removing the eyelet bolts on either side. There is not enough clearance. His solution was to either bend the bracket enough to get the bolt out and if that didn't work to cut the bolt and remount from the opposite direction where there is enough clearance. Needless to say I brought the van back home. If someone has upgraded their sway bar with a similar set up, I would love to hear your solution to pulling the old one out. Thanks George
PS - Colonial Airstream said they won't touch suspension work
