09-04-2015, 01:09 PM
#241
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Originally Posted by mefly2
Specific question...
Please post your experience with VW USA with regard to warranty claims coverage due to power train damage or failure. We like the VW Touareg, but have been told by two different dealers' service managers that VW USA will NOT cover ANY damage to the powertrain caused by pulling our 25EB. Apparently, they can read the vehicle computer to see the load parameters.
I am not sure what is stored during normal operation unless there is a fault. When I was deciding between the German SUVs VW was the only one that specifically states not to use a WD so I stayed away from it. I have had the ML350 in 3 times for issues directly related to towing under heavy loads on steep grades. While they understood what I was doing (25' Airstream at my stated dry weight of 5,800 pounds) they did not at any point say they would not fix it under warranty. I took it upon myself to prevent such an instance from happening by moving back to the 2500HD. By most accounts all the German 3.0 turbo diesels seem to be rock solid but when pushed above their intended use, especially over their respective ratings it is one's own risk if the dealer balks. Your are, after all, at their mercy. I learned this the hard way years ago when I put an aftermarket tune on a crappy made 6.0 Powerstroke Ford that they took the opportunity to deny service when it had nothing at all to do with the failure.
09-04-2015, 01:40 PM
#242
Mission
VW Touareg diesel and 31 foot Airstream
Originally Posted by dkottum
If anyone comes here to learn about Touaregs and Airstreams, it's a remarkable disappointment.
I disagree. I never would have even considered a Touareg or similar SUV prior to this thread, or have an idea what limits I would set if I were to do so. If I were still working I'd be all over a diesel Touareg with a 25' - but not larger thanks.
09-04-2015, 01:46 PM
#243
1988 32' Excella
Ojai
We already know why it can't be done, it's been reposted several times a week in the hijack of other threads. Many of us come here to learn how it can be done.
Hundreds are towing Airstreams with their Touareg, Cayenne, or Q7. Including Tino, the o.p. These are not laying in heaps along the roadside. Perhaps someone can explain that.
No one has said that it can't be done. Some have said that it's not a good idea and that they would not use the combination. I believe that the combination works, but can be improved. This isn't black and white as so many want to frame the discussion. Whenever you take a machine beyond it's design limits things are going to break or wear out faster. I have been modifying vehicles my entire life and getting them to do things they were not designed to do (as may others here have). My current truck is no exception. If it can be modified to exceed the manufactures maximum CGVWR of 18,000 lbs, why can't we discuss doing the same to the Touareg? Some of the changes I would look at would be engine tuning to get more power and torque, a larger exhaust system to reduce EGR temps at load, a larger transmission cooler to maximize life, a good gauge set to monitor vital systems and most of all the exhaust brake to increase downhill control. All of these modifications have been done to my old truck and it has increased driveability by an order of magnitude. Wouldn't they improve the Touareg as well? All these parts are available with the exception of the exhaust brake for the Touareg. In all my research on the Touareg that is the one thing that no one seems to have done. It puzzles me why something hasn't been modified to work. Maybe the boffins at CanAm might look into this and see if it's doable with an off the shelf solenoid operated exhaust brake. If the OP likes his current setup, would he like it more with these modifications?
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 300k+ (The Beast)
09-04-2015, 03:01 PM
#244
2012 25' Flying Cloud
Battle Lake
Tuco, good question on the exhaust brake. We have a Ram 1500 with similar dimensions, torque and weights to the Touareg family. It's a gas engine with compression braking. It handles like a typical truck so I don't attempt fancy maneuvers at speed, but it has the power (at higher rpm than diesel) and plenty of brakes for any grade we have been on, and we have been on some good ones.
The compression braking of our gas engine is good, but I have no issues with applying some truck/trailer brakes whenever I want to maintain a lower speed. I know the little truck could stop the whole thing easily and quickly, even on grade if I had to because I've done it. It is presumed the trailer's drum brakes would fade with steady pressure on a long grade.
My feeling is with the relatively light weight of the Touareg/Airstream combo (2,000 lbs less than a heavy duty pickup), braking would be more than adequate even without compression or exhaust brakes. And the braking is applied somewhat evenly to all eight wheels, not just two.
If the Airstream's drum brakes were prone to fade, a change to disc brakes could easily happen. Eight fade-resistance braked wheels slowing or stopping the Airstream at will is pretty good, probably very good.
So would an Airstream conversion to disc brakes be a reasonable and effective alternative to an exhaust brake for Touareg family owners? Would it be needed?
Doug and Cheryl
09-04-2015, 03:05 PM
#245
1988 32' Excella
Ojai
Originally Posted by bono
Somebody gave these numbers - I did not verified them
Touareg weighs ~5,000#, 70-0mph 177 feet
An F250 weighs - 8,500#, 70-0mph 221 feet
If you are doing 70 mph and there is somebody standing 200 feet away and you can't avoid the crash... do you think that person will appreciate F250 weight and would think: yeah, I wouldn't be hit by Touareg, but Touareg is lighter than F250, so it is OK than I am dead.
The fact is that Touareg needs less distance to stop. If it was heavier, maybe the engineers would improve the brakes. But does it matter?
This scenario would end up with the truck killing the guy and the Touareg killing or putting him in the hospital. At 70 MPH you are traveling at >102 ft/sec which gives the Touareg driver ~.2 seconds to go from bored to panic stop mode before it was to late. Human reaction times are not that fast unless you are expecting it or are just exceptional. I noticed that you did not answer the other scenarios in the post. I'll give you the stopping distance solo, the downhill control and braking ability the truck wins hands down and the stopping distance with 8800# in tow on flat land is still undecided (not enough data/info).
Dave & MJ
09-04-2015, 03:29 PM
#246
1988 32' Excella
Ojai
I think its a fantastic alternative in a pinch (expensive though). What I have found is that the exhaust brake supplies a steady braking effect allowing downhill speed control without brake input. When the brakes are applied it feels more like slowing to a stop on flat terrain. With the smaller diesel engine in the Touareg I have no idea what the amount of braking you would get (TDR forum members say the brake effect on my 5.9 is ~190hp). I would hope that the reduced weight of the rig might compensate for the reduced braking from the smaller engine. If I had the money I would add disk brakes to the trailer, but I do have to watch my penny's. Something I did find on the TDI forum was information to upgrade the Touareg's brakes to larger rotors and bigger pads. This would also add more braking if an exhaust brake was not an option. On the funnier side a few years ago a forum member here asked about an exhaust brake on the TDI forum's and a guy responded with a picture of a drag chute (classic)!
Edit: One thing to consider with the brake only option is wear on the pads. I had issues with my pacbrake for the longest time and pad wear on the truck was excessive. An updated maintenance schedule for brakes would be advised.
Dave & MJ
09-04-2015, 03:46 PM
#247
1965 17' Caravel
Curtis Wright
San Marcos
European experience
i live in texas and love towing my 1965 caravel that is 17' long and weighs about 2500# with my 2011 BMW X5 diesel.
i am in europe at the moment and have just driven from marseille to madrid. it is about 800 miles and it is the end of the major summer vacation time. i saw lots a lots of trailers on the drive. they were all being pulled by small vehicles of many types. a lot of small suv's and minivans. some cars too. no wd hitches. saw some VW's, some audi's, very few porsches and loads of bmw's of all types. many of the vehicles here are diesels.
NEVER once saw a truck towing.
they were travelling at reasonable speeds and for those of you who dont know, the costa brava is very windy. it is also very hilly.
i did not see one accident. also never saw any orphans killed when their bus was compromised by this irresponsible towing behavior.
just saying !!!
ps. i am not trying to re-ignite the truck crowd, the max towing capacity crowd, the extreme safety crowd, the "your insurance wont cover you" crowd, the warranty crowd, or the "we dont care what they do in europe of canada" crowd. they have already dominated this thread and loudly voiced their opinions.
just reporting what i have observed.
09-04-2015, 04:04 PM
#248
Hilton Head
, South Carolina
I tow a 28' Avion with an F-150 and feel confident with the truck/ trailer combination and am within its trailer and tongue weight rating. I have made my living in the construction world for most of my adult life and have towed ridiculous weights in relation to the trailer and truck at different times and been successful, but I stressed about it which will wear you out. Vehicle/ trailer combinations should allow you to feel confident without feeling so confident that you go faster and drive to aggressively because you bought the largest vehicle on your dealers lot.
The biggest reason I wanted to stay within the approved limits of my tow vehicle is if a horrible accident were to happen and I was the cause of great personal loss, injury or death my conscience would be hard enough to deal with, I don't even want to think about an attorney wielding my disregard for the owners manual as a reason to take everything I have worked for away from me and potentially put me in jail.
It is possible to tow lots of weight with a Touareg and you can be very successful doing it, but you are taking a grave risk if it is outside of what the manufacturer has approved it to be used for.
09-04-2015, 04:20 PM
#249
Vancouver
, British Columbia
Does the warranty statement say that towing voids the warranty?
It would be interesting to hear their justification. The engine can only make the power it can make. What they may be referring to is the time at higher power levels, getting at load factor or duty cycle. You should ask them what the limits are for warranty coverage, in hard figures and in writing. Then ask them how that relates at all to their responsibility to represent the manufacturer who offers the warranty, which is to cover defects in materials and workmanship.
Then you could contact VW and ask them if they know that their dealers are avoiding their responsibility to deliver warranty services as per their dealer license agreements.
09-04-2015, 04:23 PM
#250
Huh?
1975 27' Overlander
Twin Cities
A couple of thoughts.
I see a lot of comments about those dreaded 7% grades.
And comments about the need for engine brakes and heavy duty braking systems.
But is it necessary to go down those grades at 60+ MPH?
Or is it possible to go down them like they did in 1975 when they used a big GM wagon to pull my 27' Overlander up and down those same grades - slowly?
I get the impression that some people want to go up and over Donner, Rabbit Ears or the Ike tunnel as fast and as carefree as crossing Nebraska - thus the need for huge TVs.
Secondly, I also see people here who are almost OCD about all the safety stuff.
More power to them. May they forever keep the shiny side up and may they live long and prosper.
And yet, towing a trailer of any sort is inherently more dangerous than just driving a car.
I sometimes wonder why would they even bother to do it.
Maybe they do that mental math or a cost/benefit analysis and decide if they do this + that X factor1 X factor 2 they will be "safe enough" and just go for it.
But do they ever think there are others out there who feel "safe enough" with a different formula?
I do understand that people like to do the right thing.
But I don't understand why your right thing must be my right thing if I feel just as safe as you do.
09-04-2015, 05:08 PM
#251
Mission
I lived in Germany for 6 years and never saw a puckup truck. They pretty much don't exist in Europe (not like found in the USA or Australia).
Also check out European towable RVs, very small and very light - like Casitas here.
09-04-2015, 06:03 PM
#252
N/A
, N/A
Euro trailers have a different design. The axles are more forward hence the Tongue weight is significantly lower than North American trailers. It's usually under 300#. They are also narrower hence have less wind resistance. The terrain is also more forgiving there, the towing speed is lower, and travel distances are shorter. Most vehicles are also diesel and have manual transmission. Bottom line, everything towing related seems different.
09-04-2015, 06:52 PM
#253
Battle Lake
Tuco, I think the braking question, not having an exhaust brake or good compression braking, is the only thing between us and a Touareg-type tow vehicle. My experience towing our Airstreams tells me the brakes are more than adequate, and Airstream disc brakes would ensure excellent braking in all conditions. I have wondered what others experienced.
We have a light pickup and it's a decent tow vehicle. But it's an extra vehicle around home, we don't need it. There is zero chance we will ever buy a heavy duty pickup, so their qualities are of no interest. I am grateful to those who can keep the Touareg/Airstream threads on Touaregs and Airstreams.
There is another current thread on these vehicles concerning load capacities, and how it can work. Some creative ideas to keep everything within load limits. Any further discussion on loads as they relate to these vehicles will be welcome?
Doug and Cheryl
09-04-2015, 08:49 PM
#254
Mission
Trivia ...
Touareg 60-0 mph 122 feet
F250 60-0 mph 148 feet
Nothing about how each of them are equipped. Curious that they're closer in stopping distance at 60 mph. Playing the brake upgrade game you could go to GMs black lake, check stopping distance stock, then trick out both the AS and F250, and check again. But that would also work for the Touareg.
Maybe I'll do discs when I replace axles.
09-04-2015, 10:47 PM
#255
Mountain View
Other beloved TV
BMW X5 60-0 mph needs 117 feet
Porsche Cayenne 60-0 mph needs 116 feet
09-04-2015, 10:48 PM
#256
worried...happy...wo...ha
2015 25' FB International
Menlo Park
Ok, this is it for me. Unsubscribed!
Truck people, this is unreasonable and somewhat evangelistic.
One final observation from towing and being on the road for years is that the larger the truck, the lower the appreciation and concern for other drivers. I have never seen an SUV and airstream "pushing it" but have experienced quite often being power pushed by a ¾ ton truck, loaded to the brim with gear, at 75mph plus. Go figure, this crowd wants to tell us anything about safety....
09-04-2015, 10:50 PM
#257
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Respectfully ...Maybe you should ASK THEM. The last thing I want to do is alienate the service department of the local dealer where I would have to go for warranty or service work. I have politely asked and been politely told that damage caused to the Touareg by towing our EB25 exceeds the load / wd hitch / warranty restrictions. That is good enough for me. This is not an academic question - we had the vehicle ready to purchase - money in hand, but the service manager backed us away with the warranty issues.
I asked again for more specific input from VW USA owners of Touaregs that have had warranty experience with power train warranty issues after towing. Please ... facts - not more speculations or what ifs ... we still like the Touaregs but would not consider the time or cost to drive over the border to potentially invalidate our warranty on a $65K MACHINE. Any mods to the hitch system would be blatantly obvious to the service writer and reason to question why the mods were necessary. I would not invent a story to cover my actions...hence, I ask the question again ...and again ... with no factual responses so far. WE will stay with the current TV until such time as we get proper assurances from others who have already visited the scenario about which was asked.
09-04-2015, 11:28 PM
#258
Mountain View
Some people are following what they are told. Some people prefer to understand things and to reach their own conclusions. Did you try to understand what kind of warranty restrictions you would break when towing EB25?
If I had listen to what BMW stealer is telling me...
09-05-2015, 12:28 AM
#259
Vancouver
, British Columbia
Yes, but the question presupposes that some Touareg owners have had warranty claim issues. It may be better to ask for how many have had warranty work done, and then see if a subset of those responses represent claims denied. Or ask all vehicle owners how often warranty claims have been denied due to having towed something.
09-05-2015, 09:55 AM
#260
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We switched the Classic to Kodiak disc brakes at the first opportunity even though we tow with a Cummins powered 2500HD. I think the trailer disc brake conversion would be a smart idea for any trailer where a lot of western mountain driving is in the future. The parts we used were compatible with the existing axles.
The usual challenge is where to place the electric/hydraulic pump. Ours is in the front battery box.
