05-30-2020, 02:52 PM
#121
Sag Harbor
, New York
OT
Thanks Dan.
Now that I have had my afternoon nap, just a little further to go on this "memories" detour . . .
. . . I can see more clearly that old BSA Victor 441 single-cylinder kick-start MC.
Unsure of the correct term, but one of the side casings [?] had to come off the engine, and the exposed raised bolt heads were Phillips, but stripped. Using a hacksaw, a mechanic buddy carefully cut new slots into the tops of the bolts, and the impact driver got them out.
Peter
Originally Posted by OTRA15
I can still "see" the motorcycle I was working on.
PS -- Apologies Eric for the detour!
05-30-2020, 04:40 PM
#122
Airstream - Other
Knoxville
, TN
Peter that is my "go to tool" since 1979 when I was working on my 66 VW Bug.
But I don't want to talk about that now. I just pulled the scaffolding away for the Argosy. I fell like I'm at NASA launching the Falcon/Dragon today. I'm ready to launch.....almost.
[IMG] IMG_0165 by Eric Frye, on Flickr[/IMG]
05-30-2020, 04:42 PM
#123
Sag Harbor
, New York
Wow . . . looks great.
Well done! [ . . . and a long way from here --6/26/18 . . . ]:
Peter
06-26-2020, 02:05 AM
#124
Sag Harbor
, New York
Two-year anniversary, Eric, how's it going?
Great job so far!
06-27-2020, 05:56 AM
#125
Airstream - Other
Knoxville
, TN
06-28-2020, 12:40 AM
#126
Sag Harbor
, New York
Originally Posted by Eric 26 Argo
I might have to go buy a piece of land somewhere to park it on as a get-away until the Corona-19 is cleared up.
We are Covidian Camping in the driveway . . .
https://www.airforums.com/forums/f41...ml#post2375623
. . . and are also eyeing family and friends with large parcels of land.
Happy trails,
07-12-2020, 06:11 AM
#127
Airstream - Other
Knoxville
, TN
Working on a few things over the last couple of weeks. It has been absolutely miserable with 90+ degree weather and constant thunder showers. I did get the WDH set up also put together the street and curbside rock guards.
The rock guards still need some finish work but overall I pretty happy with how they attach and look. Right now the protective film is still on, which is why they are cloudy. I opted for clear Lexan to keep the bright view of the Panorama windows, one of the main reasons to pick the Argosy over other older Airstreams.
[IMG] Rock guards2 by Eric Frye, on Flickr[/IMG]
[IMG] Rock guards by Eric Frye, on Flickr[/IMG]
08-29-2020, 05:14 AM
#128
Sag Harbor
, New York
. . . It has been absolutely miserable with 90+ degree weather and constant thunder showers.
. . . I opted for clear Lexan to keep the bright view of the Panorama windows . . .
Howdy Eric,
I hope the heat has moderated.
The Lexan is a great solution! What thickness did you use, and did it take that curve well, or did you have to heat it and bend it over a form? It looks like you got a pretty "fair curve" for that large piece. Also what finish/opacity is that? It does not look perfectly "clear" IMO . . . maybe "matte" or "lightly frosted" etc.? Good privacy control IMO.
I guess the lighting could be making it look somewhat frosted . . .
08-31-2020, 05:37 AM
#129
Airstream - Other
Knoxville
, TN
Hey Peter
1. It's still hot. Yesterday out of curiosity is jumped on the scales after working out side for several hours and I had lost 2 lbs. since breakfast.
2. I used 1/8 inch Lexan. I didn't heat it as it will bend quite a bit. It is much more pliable than Plexiglas which is one reason it is better suited for the job. Also to heat an bend it you need to work in a very tight temperature range with evenly applied heat and right now I don't have the time or space to build a jig and heater to do the work. Possibly next summer. I was thinking about making another set from tinted Lexan.
3. The opacity is actually the protective film the comes on the Lexan, I just haven't taken it off yet.
09-02-2020, 03:27 PM
#130
Sag Harbor
, New York
Sounds good, thanks for the update. Tinted Lexan would be nice!
12-13-2020, 02:56 PM
#131
Sag Harbor
, New York
Hey Peter
Cooler now . . . hope you are eating again . . .
How is it going with this project?
Cheers,
12-14-2020, 09:31 AM
#132
Airstream - Other
Knoxville
, TN
Hey Peter - Honestly I have been side tracked with a Boler B1700 fiberglass camper that I was hoping to get together enough for hunting camp but some health issues slowed that down and I decided to have someone else paint the Love Shack for me because I just didn't have the time, location, equipment or skill to do a satisfactory job. A man's got to know his limitations.
I finally got a couple of quotes and picked a vendor so hopefully after the beginning of the year. One hold up was some small things I wanted to get done like remove the refrigerator vent since I went to a 12 volt unit. I also did some body work to smooth out some of the major imperfections. She won't be ding free but she is 43 so I am not too picky there.
12-14-2020, 03:19 PM
#133
Sag Harbor
, New York
Sounds good . . . thanks for the update.
02-23-2021, 01:34 PM
#134
Airstream - Other
Knoxville
, TN
Dropped the Love Shack off at the painters. Now it is a waiting game. This project is coming closer to and end. Once it is back I have to put the lights and belt trim back on.
[IMG] At Paintshop by Eric Frye, on Flickr[/IMG]
02-23-2021, 02:44 PM
#135
Sag Harbor
, New York
Thanks for the update. Did you buy new top end caps with red primer, or is that your work? I forget . . . are they steel in the Argosy trailers, or aluminum with a special primer?
Good timing for some camping later this Spring and Summer!
Happy trails . . .
02-24-2021, 04:24 AM
#136
Airstream - Other
Knoxville
, TN
Those are the original steel end caps. When I stripped the paint and cleaned up the typical Argosy rust spots I put it in primer. I had planned on painting the whole thing myself last fall but lost the available indoor space to do the job and the weather just wouldn't cooperate to do it outside and get a decent finish. Then I became impatient and decided to farm out the job.
02-24-2021, 12:35 PM
#137
Sag Harbor
, New York
Thanks Eric.
04-09-2021, 11:58 AM
#138
Airstream - Other
Knoxville
, TN
04-09-2021, 12:26 PM
#139
1978 Argosy 30
Auburn
Looking sharp
Dave
04-09-2021, 01:01 PM
#140
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Love that olive green! Nice think about the Argosy's it lets you be creative inside and outside.
Hittenstiehl
