10-09-2019, 01:57 PM
2017 28' International
Jim Falls
, Wisconsin
Where to buy European hinges?
Called Airstream and they couldn't tell me the type of European hinges for my 2017 International Serenity; nor where to buy them.
So I need a hinge for my long interior closet door (larger). I lost a screw on the inside of one. It still is holding together by one screw. Can't find a replacement screw that size. And I want the hinge because if I lose another screw (no pun intended) I will have a problem.
So where do you get these these hinges, and what kind of hinge is on the interior closet door?
Thanks.
10-09-2019, 02:31 PM
2018 28' Flying Cloud
saint albans
, West Virginia
Thanks.
screws of all sizes FASTNAl a good place,, Hinge check WW Granger they both are nation wide check for one near you
10-09-2019, 02:39 PM
Sag Harbor
, New York
Your local lumberyard or hardware store may have some. Take off one of the baseplates and look for a mfg. name on the front or back [or on the hinge]. Are you close to a Home Depot? They have a good inventory usually.
https://www.homedepot.com/b/Hardware...9aZphkZ1z0jp5l
Do these "European hinges" results look familiar?
https://www.amazon.com/s?k=european+...f=nb_sb_noss_2
Are your hinges self-closing, and how far to they open in degrees? [90/120/180 etc.]
You could also post a photo, with the hinge on its base plate next to a ruler in inches.
Good luck,
Peter
10-09-2019, 03:57 PM
Jim Falls
, Wisconsin
Good luck,
Peter
I live about 75 miles from the nearest Home Depot. The problem is I can spend a lot of time messing around driving for stuff. So it isn't like I have things close at hand. Thus I buy 90% of my stuff on line. UPS has a path worn to my house. The joys of living in the boondocks. But it has pluses.
Anyway I have a call into a dealer parts person where I bought the AS. I thought if someone knew right off it would save me a lot of research and headaches. The problem with online is hard to find the exact hinge. I tried and it was frustrating. Even Airstream couldn't give me the part number. And the Airstream parts guy I called is also taking time searching for the part number. So if they are having difficulty.... oh boy.
10-09-2019, 04:47 PM
1965 28' Ambassador
Oviedo
My father in law was in the custom cabinet business. All of his cabinets used European hinges. He purchased them from Hafele https://www.hafele.com.
I am in a vintage rig. However, when I do my next remodel on her, I will be visiting these guys for my hardware.
10-10-2019, 07:03 AM
saint albans
, West Virginia
Thanks.
For the missing screws try a company call FASTENAL,,, The hinge try GRAINGER they both are a national chain
10-10-2019, 07:25 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
For the hinges. Woodcraft supply. Rockler. Highland Woodworking. Woodworkers of New Mexico. You might fine the makers name on the hinges. The hinges all fit the same mounting hole so you just need to find the style ion the hinge.
10-10-2019, 10:29 AM
2019 27' Globetrotter
McHenry
Airstream cabinet parts supplier
Thanks.
Hi Daquenzer, I Googled "Airstream Cabinet Hinges" and found High Sky RV Parts. Looks like they've got just about everything and photos of parts to help select the one that matches.
https://highskyrvparts.com/New-Airst.../Cabinet-Parts
By the way, how's the Fall Color up in Door County at the moment? We stayed at Egg Harbor Campground last year at this time and it was beautiful.
Good luck!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
10-10-2019, 11:10 AM
Sag Harbor
, New York
Post #3:
Waste of time going through an AS dealer IMO.
Post some photos per earlier advice, and someone will help you spec out the hinge.
Plenty of links in earlier posts -- your hinge is in there somewhere IMO.
Peter
10-10-2019, 11:14 AM
Sag Harbor
, New York
Is there no mfg. info or part no. stamped anywhere on the hinge or base plate?
Originally Posted by Bill M.
. . . You might fine the makers name on the hinges. The hinges all fit the same mounting hole so you just need to find the style ion the hinge.
. . . Take off one of the baseplates and look for a mfg. name on the front or back [or on the hinge].
10-10-2019, 12:01 PM
2019 30' Classic
Belleville
My Classic uses hinges and hardware manufactured by and available at https://www.hafele.com/us/en/
10-10-2019, 12:15 PM
2022 25' Flying Cloud
NCR
, Ontario
http://www.leevalley.com sells most types of hinges
10-10-2019, 02:09 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Email Airstream at : partsinq@airstream.com. Describe and Ask for a part number. It helps if you include a photo. I’ve done this twice recently with immediate responses. Then I bought the parts from out of Door Mart. Both were obscure parts but OOD had them in stock. Good luck.
Antique Pedaler
2021 Caravel 20 FB
10-10-2019, 02:32 PM
2015 28' Flying Cloud
2014 25' Flying Cloud
Waxahachie
Out of Doors Mart has the hinges. I just bought a couple to replace a few in my 2015. Good luck
10-10-2019, 04:47 PM
Jim Falls
, Wisconsin
Good luck!
Jeff
My wife and I were driving back from a trip and think the fall colors seem a bit more muted this year. But my guess is they will peak in the next week. We have a maple tree in our back yard that hasn’t turned yet. That’s very unusual. Late Spring? Who knows. The problem is we are going to get 20 to 30mph winds Friday. Not good for the leaves that are turning color. Will get blown off.
10-10-2019, 04:59 PM
Jim Falls
, Wisconsin
Good luck!
Jeff
By the way thanks for the web page. Got them ordered. Exactly what I was looking for.
10-10-2019, 08:43 PM
2020 25' Globetrotter
Half-timer from
, New Hampshire
In my life before retirement, I was a studio furniture maker and worked with European style hardware regularly. I have some corrections and recommendations for some of the posts made here:
Woodworkers Supply (NM, WY, and NC) has a decent range of this kind of hardware, but my recommendation for a wider range and better customer support is Woodworkers Hardware in Minnesota. They have a good online catalog, but even more helpful telephone reps who can help you sort out whatever is needed.
There are a few variations of hinge boring patterns and styles among the major manufacturers, so be sure you are ordering the same brand as the original equipment. Otherwise, they may not be an exact replacement.
10-10-2019, 08:45 PM
Half-timer from
, New Hampshire
Also, Highland Hardware is the correct name of the company in Atlanta.
