Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 07-19-2015, 06:31 PM   #1
2015 25' Flying Cloud
Eugene , Oregon
Have to Slam the Door on a New AS?
OK maybe I should ask the dealer that we just bought our new AS from, but while out for our first trip (6 days), my wife and I were rather taken back by how much force it takes to close the door in order to get it to close completely. Yes, I know these are built solidly, but sheesh, the force it takes. This is easy from the outside, but seems a bit difficult from the inside. Besides, in most tight parks, the noise of slamming the door shut later in the evening can't be a nice thing for your neighbors to hear. Is this because the seals are new or do I need to adjust something, if there actually is something that can be adjusted? Or ask the dealer? Thanks for any help on the subject.
ltorgy is offline   Reply With Quote
Old 07-19-2015, 06:35 PM   #2
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I slam my 2006. Enjoy your new Airstream, but by all means ask your dealer, mine was purchased used so I did not have a dealer to go back to, and I will be waiting to hear what they say.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 07-19-2015, 06:41 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, this is normal; I have adjusted my door perfectly, but these bodies flex and make closing your door harder at times. The worst thing you can do that will make your door hard to close is to crank too much on your stabilizers. When used, I crank mine until they hit the ground and give them another one-half turn. A very common mistake is when someone tries to use their stabilizers to level their trailer. Use blocks under your tires to level side to side and use your tongue jack to level your trailer front to back. Then use your stabilizers to do just that, stabilize your trailer as mentioned above.
Hope this helps you.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is offline   Reply With Quote
Old 07-19-2015, 06:42 PM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Our door was misaligned on our 2012 (purchased new). We had it fixed at Jackson Center on warranty. There was a point where either the misalignment, banging or both created a very dangerous condition - twice I was unable to get out of the trailer from the inside without a few minutes of finagling. If left alone, i wondered whether that condition could be permanent. Not a fun thought. They corrected it at the factory and it has worked perfectly ever since. Have it fixed on warranty.
SteveSueMac is offline   Reply With Quote
Old 07-19-2015, 06:51 PM   #5
AWCHIEF's Avatar
2006 23' Safari SE
Biloxi , Mississippi
Images: 33
Slam away, both my Airstreams have had tight well sealed doors. I consider it a plus and a sign of quality construction.
MICHAEL
Old 07-19-2015, 07:34 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I guess mine is loose, sloppy, and shoddy...I can push it closed with one finger.
CRH is offline   Reply With Quote
Old 07-19-2015, 07:42 PM   #7
1974 Argosy 20
Kooskia , Idaho
My 2014 FC 20 had a door which needed slamming. I had the dealer adjust it and it is much better now. Not one finger close, but acceptable. So, have it on your list when you take it in for warrantee work.
Old 07-19-2015, 07:45 PM   #8
2023 25' Globetrotter
Manheim , Pennsylvania
Well ours did not close properly when we got it. Then the door latch post loosened on it's own. Before I used a crescent wrench to snug it up, I checked and adjusted the alignment. Works fine now.
Jukeboxfun is offline   Reply With Quote
Old 07-19-2015, 09:40 PM   #9
Eugene , Oregon
Thanks everyone for the suggestions. I never would have thought about the stabilizers and the level of the trailer. As a point of reference, I do level my trailer and I don't crank the stabilizers too much. I'll let everyone know what the dealer says.
Old 07-19-2015, 10:13 PM   #10
Ag&Au's Avatar
Port Orchard , Washington
I cured the hard closing door on trailer when new, by thoroughly lubricating the latching mechanism.
Ken
Ag&Au is offline   Reply With Quote
Old 07-20-2015, 05:45 AM   #11
Mantua , Ohio
I suspect Bob has hit it on the head. Leveling properly helps a lot but any AS I have owned needed the door shut firmly, the Avion also. As the seals age it sometimes get easier, but that is another problem.
xrvr is offline   Reply With Quote
Old 07-20-2015, 06:40 AM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Lubricate the latch contact points and mechanism and hinges frequently. Wipe the seal with Aerospace 303 or silicone. Ensure the adjustment is good, should be able to close with a flat hand on the latch and a good firm push from a few inches open, hard slamming is probably not good for the parts over time. Yes, they can be harder to close from the inside.
Uneven parking spot or uneven tightening of stabilizers can twist the frame/shell making the door hard to close, as mentioned earlier.
Doug and Cheryl
Old 07-20-2015, 11:44 AM   #13
Check your hinges
We were having trouble with our door (2013 AS Serenity 28') I noticed the screws on the lower door hinge were loose. Tightened the screws now everything works well. Glad I noticed before losing the screws entirely.
Krusty Buns is offline   Reply With Quote
Old 07-20-2015, 11:49 AM   #14
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I still have to close mine firmly, but it is easier to close than before it was adjusted at Jackson Center.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
m.hony is offline   Reply With Quote
Old 07-20-2015, 12:41 PM   #15
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Open a window or vent. Does the door close more easily?
Kelvin
2008 Classic 25fb "Silver Mistress"
2015 Ram 2500 6.7L Cummins. Crew Cab, 4x4, Silver
KJRitchie is offline   Reply With Quote
Old 07-20-2015, 01:13 PM   #16
knunut's Avatar
2023 16' Basecamp
Chgo. N.W. Burb's , Illinois
Even on a 20ft., if you crank levelers down too much door is hard to close.
We do same ,down to ground plus 1/2 to 1 full turn. I also check after a day or two.
knunut is offline   Reply With Quote
Old 07-20-2015, 01:35 PM   #17
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
What ROBERTSUNRUS said and several others have advised. Unless you level the trailer with the wheels and axles, you will torque the body and give your door fits.
Check this out:
Finally by slamming the door, you'll eventually bend the little pot metal locking mechanism within the door latch mechanism so the Paddle Opener (does it have a name) won't function. Been there.
The Ice Man is offline   Reply With Quote
Old 07-20-2015, 02:00 PM   #18
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I agree with lubing the latch contact points. Then to close just place your palm on the door and firmly close it- keeping your palm on the door till the end.
2019 Ford Expedition Platinum
Wayne&Sam is offline   Reply With Quote
Old 07-20-2015, 02:13 PM   #19
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
Everybody seems to suggest that its OK to slam the door, and I have seen AS guys on you-tube extolling the virtues of the AS by slamming the hell out of the door.
With the conservatism shown by the group, I am rather surprised that slamming the door is seen as OK. As with any mechanical interface, the more times you stress it, sooner or later it will fail. Not to mention it's loud and wakes up my wife, since I am the one to take the dogs out in the early AM or go stargazing late at night - while she sleeps.
I close the door using the technique learned in the US submarine force - if on the outside of the door, I gently bring the door into contact with the frame, and then push shut with my hand on the door, until I hear the latch click. If I am on the inside, I similarly make quiet contact, and the pull the door shut until the latch clicks.
Regardless of what we think of the ability of the AS to absorb abuse, its not necessary and can be avoided.
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
tyggeln is offline   Reply With Quote
Old 07-20-2015, 02:14 PM   #20
Kelvin
That's one air tight trailer!
Slam door to lock? john4170 Doors & Locks 24 04-24-2014 11:16 AM
To have or not to have...vent covers??? Director Roof Vents, Skylights & Fans 2 10-21-2007 01:25 PM
I have a 1965 Caravel and if I have a flat tire toastie Tires 11 09-07-2006 11:51 AM
