After spending quite a bit of time trying to pull the shower unit out (including attempting to cut through as much of the adhesive used to install it), I finally concluded I needed to remove the supply lines to free it up. Since I couldn't reach the connections which were under the kitchen sink and behind the back wall of the cabinet, I cut a hatch to provide the needed access. Once I was able to remove the supply lines, I gained just enough wiggle room to cut through the copious amount of adhesive that had been used to glue the unit in place. Why? I have no idea.
I'm now at the point where I have removed the old adhesive both inside and out, and used a dremmel tool to enlarge the opening where necessary to accept the new unit. By the end of the day today, I realized that the connections for the supply lines on the new unit do not line up with the existing plumbing. Tomorrow's job is to address that issue! But making progress!
KMM
