03-16-2002, 01:51 PM
Airstream Driver
1994 30' Excella
1992 35' Airstream 350
Austin
Rear Air bags
ALANSD wrote: <<<<<I checked my rear air bag valve and found no air in them. I tried to air them up to 100, never got past 50psi, then by them time I rechecked, they
were at 0 again. I guess I see why the rear seems "bouncy"- any ideas on how to isolate the problem? It could be the small tank, or the lines , and of course the bags...I wondere if the compressor was coming on as I never hear it, guess the whole system could be replaced..>>>>>>
Besides being bouncy, you must be very low in the rear.
With the system @ 0 psi, the aircompressor should come on, when you turn the ignition on.
Check air compressor fuse. You could have burned out the compressor.
Use a spray bottle with water and liquid soap. Shake the bottle to make it all foamy and spray all the fittings and the 4 valves mounted on the leveling valve bracket.
try inflating again. If the air loss is as rapid as you describe, I suspect a leaky bag.
Don't think about replacing the entire system, too costly.
If this does not show you anything, get compression fitting type plugs at your local plumbing store. First plug compressor side of tank, then airbag side, to isolate.
more later
03-16-2002, 03:38 PM
1966 26' Overlander
Woodstock
It doesn't seem very low in the rear , actually sits level as measured by a level in the kitchen area. I checked the air pressure at the valve on the bottom of the accumulation tank, which sticks out the bottom of the rear luggage box whwre the compressor is located. There are two spring loaded screw ins that I am not sure about as per function, a large one and a small one side by side under a small grey cover over the wiring for the air sysytem. I would assume the air pressure should be checked at this valve- looks like a tire valve.
03-16-2002, 04:02 PM
Airstream Driver
1994 30' Excella
Austin
The spring loaded screws under the grey cover are part of the pressure regulator. They determine cut-on/cut-off pressure, which should be ~70 (compressor turns on)~100 compressor turns off.
Don't mess with them, unless you have a pressure gauge inline.
Have you tapped on your airbags, do they feel hard. You know, when they are flat.
There should be a check valve in the system, that does not allow air to feed back into the compressor.(because they all leak!)
If that check valve is located on the air bag side of the tank, your bags could hold pressure, even if the tank is empty and the compressor is broken.
03-16-2002, 07:06 PM
1966 26' Overlander
Woodstock
I will check it out further tommorow. I haven't yet checked the fuse for the compressor. I checked air pressure at the vavle coming out of the bottom of the accumulator tank, and that was where I was trying to add air as well, as it read 0. The bags do look inflated to me, althought the ride is a bit bouncy in the rear, not so bad as to hinder driving, but still not as it should be. That's what made me check in the first place. The manual says this valve can be used to add air, so I assume its where you would check system pressure?
Here is a quote from info I had saved in my collection if anyone else needs this-
"I had a problem with my air bag compressor. It would run hot smell strange and some times blow fuses. I decided to replace it. I purchased a heavy duty 12 volt compressor from the local department store, rated at an eight hour duty cycle and a 250 lb. capacity. I wired it directly into the regulator switch that is in the compartment, and I plumbed the the hose end onto a barbed fitting with a back flow preventor and an air nozzle inlet for emergencies. The whole thing cost about 50 dollars and it is working great. "
also this one
"I had the front and rear shocks replaced on my MH with the bilstien shocks specified for the P30 from camping world. All works well."
03-16-2002, 09:45 PM
Airstream Driver
1994 30' Excella
Austin
I only have a drain plug on the bottom of the tank. For many reasons, I decided to install an inline pressure gauge, which reads the pressure from the compressor to and including the tank.
During ignition on, the pressure reads 80-100psi, when reaching 80, the compressor kicks in.
When ignition off, the pressure may drop to 0, if parked for long periods of time, but the bags always stay fully inflated.
Two things keep the bags inflated, even if the pressure is 0 at the tank/compressor side:
1. the solenoid valves that are closed with ignition off.
2. the check (or back flow) valve, which I placed on the air bag side of the tank.
I guess the factory set-up would be to have the small inline check valve right at the compressor, but that means with a tight system, your compressor may not turn on for weeks.
With my set-up, the compressor kicks in every few days, which is assuring.
03-17-2002, 07:32 AM
Just a member
1978 28' Argosy 28
Lutz
Alan,,
My MH does not have the automatic compressor, I have front air bags aftermarket installed. When I got home for our first trip I checked the air bags and one was at 0 the other at 40 PSI. On my bags there is a valve at the bottom of the bag where th inflator hose attaches. That hose was loose and allowing all of the air to escape.
I do not know if your setup is the same but in talking to other MH owners this is a trouble spot. I wonder if the compression/expansion of traveling causes the bag to rotate in place, thus unscrewing the hose??
I may have to dissassemble and reinstall with some loc-tite.
Just my 2 cents
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
03-18-2002, 10:41 PM
1969 27' Overlander
, Michigan
I had new front air bags installed inside the coil spring when I picked up my coach in Phoenix last year. I noticed one of the air bags deflates over time. They should be inflated to 55 psi. It makes a huge difference in how the coach handles. I suspect the same problem you describe causing the leak. I'll check it out next time it is nice enough to craw under the coach.
Alan, does your coach have a Tag axle? If so, it is very important to keep the rear air bags inflated to the proper level. On my coach, the compressor pressurizes the accumulator tank. There is a mechanism attached to the tag axle that opens the valve between the accumulator tank and the air bags when the rear of the coach is sitting too low. In this situation, the Tag axle is taking more weight then designed for and the main axle less. The bags inflate (more) raising the rear of the coach until the coach again sits at the proper level to balance weight between the main and tag axles. The compressor runs when I turn on the ignition if the coach has been sitting for a while.
03-19-2002, 08:53 AM
1966 26' Overlander
Woodstock
No, mine is a single axle dual wheel. I believe the bags are inflated, although I don't think the compressor is coming on..
The coach sits level and doesn't ride too bad, but as I had said it does bounce a bit in the rear making riding back there not the most pleasant.
I am going to get new shocks put on soon and have the tech look into to air bag situation. It may be that the valve sticking out the bottom of the accumulator tank is not working right. Its an inexpensive tire type valve, sticking through the bottom of the rear storage locker, where dirt and crud could really affect it.
May get the shocks before the rally...
04-03-2002, 01:09 PM
1966 26' Overlander
Woodstock
I had new rear shocks installed, the old ones were completely worn out. The technician said the air bags and compressor are fine. He told me that the valve at the bottom of the accumulator tank would allow air to be added when an inline valve was opened, and otherwise this valve would only release moisture from the tank when depressed. A relief for me, as the system is doing what it is supposed to do. Now on to Mystic Springs!
10-27-2005, 12:48 PM
1966 26' Overlander
Woodstock
so after three yrs of messing around , I removed the compressor, checked all the lines, removed the tank which had rrusted through...added a schrader input valve, and all is well. Air ride is sure sweet.
12-05-2005, 08:38 AM
I have a similar problem...79 28' center bath...woke up from my first and only camping trip with the air bags empty...bypassed the pressure switch to cut the compressor on with no luck...filled the holding tank with an aux compressor with no air getting to the bags....two weeks later I pulled the cover off the pressure switch and the compressor came on and filled the bags..installed new pressure switch and all is still working after 5 days...po said solinoids are wired to pump which is wired to switch which is always hot....I hate to have this happen again out in the wilderness...any suggestions...joe
12-05-2005, 11:35 AM
RivetAddict
1986 34.5' Airstream 345
Louisville
, Kentucky
Joe,
Sounds like you found the issue. The two big things with the bags are water in the tank and cracks in the bags. Other than that it's maintenance of the compressor, solenoids, etc.
One thing; why didn't the bags fill up with your pressurized the tank from an outside source?
Steven Webster
AIR 1760
12-05-2005, 01:00 PM
1966 26' Overlander
Woodstock
The bags are holding air now? For awhile mine seemd like they were holding up. The hole in the tank must have been smaller, and it eventually just rusted though. Now its simple for me I have no compressor, no tank, no switches or power lines to worry about. Just a manual valve for input.
So here is a question- can these be overfilled? Or does the check valve bleed off the correct amount of air to maintain the pressure? I am thinking this is a no....and I need to be careful how much air I put in.
12-06-2005, 08:07 AM
This is the first air suspension I've been near so I know nothing...I think the bags failed to fill when I applied air pressure because the solinoids did not open....po said wired directly to compressor so open when pump comes on...but at one time I had compressor on with bypassing the pressure switch and also adding outside air pressure with no increase in bag ride height...I hope air was going to least pressure like out the compressor instead of in the bag...to be safer I'm thinking add something to add air directly to the bag...any thoughts??? joe
12-06-2005, 08:47 AM
RivetAddict
Louisville
, Kentucky
Joe,
The bags should be filling from the air tank. I'm not sure about the setup on the smaller floorplans (on my 345 there are leveling values on the tag axles which add or release air based on ride height).
Anyone with a smaller floorplan that can diagram out the flow for Joe?
Steven Webster
AIR 1760
12-06-2005, 08:51 AM
1966 26' Overlander
Woodstock
On ours there are leveling valves as well. The arms run under the axle, the bags sit over them.
If the valves are working they will add air as needed.
You also have to check your tank to see if it has too much moisture in it (this is what rusted out mine), there should be a valve underneath the coach where the tank sits above it. You can use it to let moisture out, but not to add air in. The switches and power supply are right next to the tank...in the same area.
also check this thread-
http://www.airforums.com/forum...ghlight=airbag
02-02-2006, 07:58 AM
1979 28' Argosy 28
Cullman
Check out this DVD, listed on Ebay occasionally. It may not be there now but it is sometimes. Type a search for (RV MOTORHOME AIR BAG SUSPENSION DVD L@@K!). The bags on my bus where messed up when I bought it. The problem that I had was identifying the air bags and going through a local RV dealer. I took them in to Fleet Pride and they knew what I needed and I had them in about two weeks.
02-02-2006, 08:20 AM
1984 27' Airstream 270
Skaneateles
, New York
air suspension
We have the same set of problems. We have gathered information from this forum and other sources and are working toward a solution. We will share what we learn if we succeed. Cheers Tom
05-30-2006, 01:02 PM
1996 28' Excella
Portland
On my coach the whole compressor and leveling system was bypassed and there are schrader valves on the wheel wells for inflation.
In my 5 weeks of ownership I just realized that I've had them overinflated. I had them set about 3.5 inches too high(way too high); measuring from the top plate to bottom plate. This made the wheel wells about 3 inches higher over the tires, and the rear of the coach about 7 inches higher.
I set them this way for 3 reasons:
1. I didn't want to scrape the rear end leaving my driveway,
2. I thought more pressure = stiffer/better handling,
3. I didn't know any better.
I recently installed a Air-Lift controller so I can adjust the air on the fly. I also read some info from this forum about the proper height, so half way through my trip this weekend I decided to try the proper height. The coach handles so much better. Going back to the height I had it at before makes it feel like the coach is going to tip over during turns. Moving all that mass so much higher made the coach want to tip. lowering it back down made for a drastic improvement.
So now I air up the rear end when I have to negotiate my driveway, then I air it back down once I'm on the road.
Now that I have working brakes and proper handling, I don't feel quite so out of control.
-Kevin
1996 Airstream Excella 28'
2007 GMC Duramax 4x4 CCSB
05-30-2006, 02:02 PM
Skaneateles
, New York
air suspension
OutOfControl etal,
This forum is so helpful in keeping these magnificent old machines going. I'm personally grateful to many contributors.
We bought our 1984 Airstream 27MH in Oklahoma this past January. I spent part of 2 days going over every system. I was quite happy because everything worked. Everything had been repaired but not renewed. So I set out for the 1400 mile drive home to Upstate NY with the coach level and 50 F air temp. 12 hours later in sub freezing weather , the air compressor quit because it couldn't supply air to the air bags. I slept for the night and early in the AM I called Fred Hinds of Fred's Airstream fame. He helped me by telling me to fill the accumulator tank and also told me about the forum.
To shorten the story, we put in a rebuilt compressor from John Clement in California, pulled the check valve out of the line to make sure it was working, then we replaced the main leveling valve at the rear axel. Everything is working perfectly now. I run the front 2 air bags at 55# (which registers 60 on my dashboard guage) and I run the 2 rear air bags at 90# (which registers at 120# on dashboard).
The water in the system and freezing temps can stop the system from working and even damage parts. When the rear airbags are deflated the front head lights point into the trees. They don't even illuminate the road and the coach bottoms out.
We have also put on headers and completely redone the fresh water plumbing system. We're good to go for the rest of the summer...we hope.
Thanks again to all. PM me for any specifics. Cheers, Tom
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Rear air Bags
stuart2 |
Mechanics Corner - Engines, Transmission & More... |
15 |
04-01-2004 12:32 PM |
Air pressure for rear air bags
Jon Smith |
Towing, Tow Vehicles & Hitches |
2 |
08-12-2003 09:08 PM |
Z71 or Z85?
River Rat |
Tow Vehicles |
7 |
05-09-2003 04:40 PM |
