Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1964 Bambi II
Old 09-19-2014, 11:59 AM   #1
1964 17' Bambi II
Huntsville , Alabama
64 Bambi II Shocks
Just bought a Bambi II and have been inspecting the whole tailer. I noticed the shocks look original and should probably be replaced. Anyone know what might be a good modern replacement part?
Jayjj1974 is offline   Reply With Quote
Old 09-19-2014, 12:13 PM   #2
You can use the current shock that Airstream has been using since late 1968.
But, you might have to shorten the vertical bracket so that the distance between the studs is no more than 14 1/2 inches.
However, that dimension should only be used when using a "known" good axle.
That dimension will be a lot less if the axle rubber rods are history, which happens after about 25 years, and a lot sooner if the trailer was parked and not moved for a couple of years.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-19-2014, 12:17 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Your trailer likely has vertical shocks. Monroe makes one that works. That's what I put on my 66 Trade Wind. I'll see if I still have the part number.
David
PS Monroe Gas Magnum P/N 555003. I purchased mine at NAPA. That is the shock I put on my 66 Trade Wind.
There is a special Airstream "horizontal" shock. I think that shock began in 1969. Andy at Inland has described this special Airstream shock many times.
dbj216 is offline   Reply With Quote
Old 09-19-2014, 12:40 PM   #4
Antiquepedaler
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
Laramie , Wyoming
Images: 11
If the shocks look original, how about the axle? If so, Andy would probably suggest a new axle to go with the shocks. That's one of the first things I did.
Antique Pedaler
2021 Caravel 20 FB
Antique Pedaler is offline   Reply With Quote
Shocks or no shocks? Thisisliving Shocks 34 07-01-2013 08:59 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
Shocks or no shocks with new Dexter Axles? nick6930 Axles 5 04-13-2009 03:41 PM
