On the last trip I failed to completely close my bathroom cabinet and one of the cheap latches that come from AS vibrated loose. Can anyone suggest better latches? I have tried to put a gas strut on the door but can’t make one work. Thanks
They only solution I found was the gas strut.
I also could not figure out how to do it but my son did in about two minutes! There are several threads about this problem.
Another tip,when you re-hang the mirror use the opposite end so you have fresh area to drill your holes.
