Classic case of form follows function. If your goal is make it lighter, better state of the art than $76,000 new ASs, weather from 120 degrees to 40 below zero, be totally off
grid only limited by resupply of water, propane and kerosene, then buy it. Female friendly or not. Sleep 6 or not. My
1958 Caravanner 22'. $4,101 missing much of interior. Great because - gutted it. Build back; 4400 watt dual fuel generator on tongue. 7,000#Bulldog coupler
reset to 19" height. 2,500#electric jack. 3 new 15" rims, 8 ply tires, SS moons. Rear bumper
cut reshaped and welded to lower spare to bottom belly height. Intex fold out queen bed inflatable sofa at each end, fold up twin 4 " foam mattress at each end which fold up when not in use. These rest on frame with woven 2" seat belt webbing ( like Navy ship bunks) 9 each king blankets ShopCo closeout ($8.89 each) for beds, 2 layered curtains w bubble pack guts, and room curtain partitions-each end. Waterless urinal. Porta pot. 100% duty
12v air compressor, aluminum tank. 2 T-105 Trojans. 3,000 watt pure sine wave inverter. 6/12 volt battery charger for all battery types w/ trickle 20a/ 100a jump. 2 door 3.1 cu ft frig, energy star draws 1.45 amps. 8,600 Btu house a/c runs at 4.1 amps- 11.4 Seer rolls out
from cargo hatch roadside. Military tent heater adjustable from 20,000 to 45,000 Btu and TEF-111 thermoelectric fan moves 450 cu ft/min ( no electric-runs on heat power). Chopped
axle ends and made independent air bag suspension so rig will sit on ground or 11" clearance for off road. Huge SSsink. 2 each 1,000 watt NUWave induction cook tops, 2 Coleman 2 burner stoves (1 propane-1 kerosene). 45,000 Btu turkey fryer with 30 quart aluminum pot. 100,000Btu burner for 16" woc cooking. Expensive true woc. 9 storage containers top opens or clear plastic side folds up. SS Cuisinart BBQ grill and flat griddle to fit. Microwave. 3/4 " packing house cutting board, SS counter and wood counters fold down on each side of cabin.
Am in process of lifting cab 12" to make basement - yes my floor was bad at both ends and at door. Steps rusted and missing so entry will be 6' air powered slant ramp extending from basement. Many hooks , fittings,
12v ad 110v wiring stuff, propane set up parts. I have yet to go over $5,000, which includes all welding and frame beef up. TV trays are very large prison "plates" with varied detents for different foods. Lawn chairs and every thing but frig
will fit in 4" spray foam insulated basement. In side is pretty much unobstructed great room.
One of the new floor pieces will be lifted to become a 5' round poker table. Belly pan will be .o60 EPDM rubber roll roofing (easy to repair and flexes for small objects at full kneel down)
Wheelchair friendly and generator has wheel kit to roll generator inside to prevent theft when
on extended outings. I've weighed every piece going in and should be 4,180 (less fluids) OTR. Bose sound and flat screens not purchased yet. Every single item so far bought on sale,
close out, display item, dented etc. Have been accumulating contents since last OCT. Many
unique features not covered here. BUY IT AND BUILD IT FOR UNDER 10K.
