08-03-2014, 06:58 PM
#101
1972 25' Tradewind
Hopkins
You may be disappointed to find that the hose for the outdoor shower is somewhat short (depending on what unit you install...I installed the new AS stainless steel unit), especially if mounted as low as the battery box. That is where I was going to mount mine. But at 6'2" tall, I didn't want to have to stoop over to rinse off. So, I moved the location up a bit.
08-03-2014, 09:43 PM
#102
1972 21' Globetrotter
Culver City
Ugh! My plans foiled again! I'm 6'2 as well. I will look into one with a longer hose or deal with the stooping for how rarely I will probably be using it. Thanks for the heads up though!
08-06-2014, 08:25 PM
#103
Culver City
Almost got all the belly pans off, what a gross job. They are pretty rough so I'm going to make some new ones using these as a template.
08-06-2014, 08:49 PM
#104
1999 34' Excella
Hillsboro
Are to you DONE yet?????
Looks like great progress! Stay strong!!!
Peace and Blessings..
Channing
WBCCI# 30676
08-06-2014, 09:54 PM
#105
Culver City
Thanks for the encouragement. I am longing for the day that I get to start putting stuff back together. This part is not fun.
The PO added some junk in the back that is making this 10 times harder than it had to be.
08-09-2014, 02:26 PM
#106
Culver City
Bought some aluminum today, 4 sheets of 4x12. They didn't have any C channel to match the airstream size of 1 3/4 inch so I bought this square tube and I'll cut it in half to make my own. Wish me luck as I have never worked with metal before :/
08-09-2014, 02:30 PM
#107
1999 34' Excella
Hillsboro
Marco.... I think the C channel is thinner than the square you found... making it 'turn the corners' at the rounded ends is challenging... I look forward to how you approach that...
Don't heat this like you might do to steel..
Channing
WBCCI# 30676
08-09-2014, 06:25 PM
#108
Culver City
Thanks cwf, it is MUCH thicker, all of my curves are salvageable so I won't be doing any bending. Thanks for the heads up On not heating it, I didn't know you shouldn't do that.
08-09-2014, 06:46 PM
#109
Culver City
Just got all the plywood for the new floor. I splurged on the marine grade. $100 a sheet. My year (1972) takes 3/4 thick.
I'm going to check the boating forums on how to seal this stuff, unless anyone here has any suggestions?
08-09-2014, 09:17 PM
#110
1969 31' Sovereign
Paris
A few coats of spar urethane will do the trick. It's the same stuff they use to seal the plywood transoms on aluminum boats.
08-10-2014, 05:22 AM
#111
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
And some folks have used polyurethane and epoxy products to seal up the plywood. Concentrate on the edges as that's an area where water likes to absorb into the wood. There is plenty of information on floor sealers in these forums. Take a look and pick one that suits your fancy.
David
08-10-2014, 01:34 PM
#112
Culver City
I tried replacing the shower pan. Please help.
Thanks David and e5earley. I'll dig into the forums for sure! I never want to have to do this again, so I'll take the time and get it right.
08-10-2014, 01:38 PM
#113
Culver City
So 3 hours and 3 angle grinder blades later, I got this nonsense make-shift gray water tank removed along with the low to the ground metal sleigh things protecting it. Sorry kids but no more spark shows behind my trailer on the highway!
08-10-2014, 02:03 PM
#114
1967 26' Overlander
Bugtussle
, Oklahoma
Are you going to be able to sneak all that black pipe into your neighbors trash cans?
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
08-10-2014, 02:09 PM
#115
1976 25' Tradewind
Make about 3-4 big potato cannons with the scrap from that 'tank'.
Matt
08-10-2014, 02:21 PM
#116
1999 34' Excella
Hillsboro
Get West Systems Epoxy then saturate upper and lower surface. Cut edges to fit. Seal edges with Epoxy...saturate!
Channing
WBCCI# 30676
08-10-2014, 04:21 PM
#117
Culver City
I'm liking the potato cannon idea! Blow off a little steam after this mess. I 'm still not done removing all the junk the PO welded on. I think I'll give up for now and continue taking the belly skin off now that I can access it.
And thanks for the epoxy tip, I'll look more into it. This wood is going to basically be 98% plastic when I'm done with it.
08-10-2014, 04:26 PM
#118
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
You are going to need to find some really really really big potatoes....
08-10-2014, 04:37 PM
#119
1999 34' Excella
Hillsboro
Marco.. Your choice of marine grade plywood is spot on. There are "plys" are higher grade with few, if any voids. Based upon your skills, I wager you have seen voids in the AB plywood a from The big-blocks store.
Having tried both styles in boat builds and repair, gimme Marine Grade for this task.
Also, there are tips on creating drains around the perimeter C channel to move water out rather than in.
Channing
WBCCI# 30676
08-10-2014, 04:39 PM
#120
Culver City
The garbage fairy won't have to come out this time
