Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Liner > 1950-1956 Liner
Old 06-12-2015, 10:10 AM   #1
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Red Barn Liner
Finished the Red Barn Safari.....and no rest in my soul. Meet, and follow, my new friend....the Red Barn Liner. I can use all the help and info available here.
Name:	Red Barn new resident.JPG
ID:	240500   Click image for larger version
Name:	1953 Liner at home 1.JPG
Name:	1953 Liner at home 2.JPG
Old 06-12-2015, 10:59 AM   #2
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Inside pictures, please.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 06-12-2015, 12:06 PM   #3
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
inside as found
for you Bruce....you have "been there" before. Lots of work as this is a park model.
Name:	53 aft curb side.JPG
ID:	240507   Click image for larger version
Name:	53 Galley.JPG
Name:	53 interior rough..JPG
ID:	240509   Click image for larger version
Name:	53 toilet.JPG
Old 06-12-2015, 02:58 PM   #4
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
It is pretty though. The ones I drag home look much worse than that!
Bruce
Old 06-12-2015, 03:10 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Melody Ranch,
What is the serial number on your Liner?
Bill
Just my personal opinion
https://billbethsblog.blogspot.com/
Old 06-12-2015, 03:45 PM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
O5003 Bill. I am, and have been a fan of yours for years.
Old 06-12-2015, 09:56 PM   #7
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Thanks, three earlier than mine and from Ohio also. Someday we need to meet.
Bill
Old 06-25-2015, 08:58 AM   #8
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Torflex today
Axles on the way.
Name:	Axles this week.  .JPG
Old 06-26-2015, 08:24 AM   #9
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Hornets
Something I have never encountered before.....hornets. I saw a few as I tried to get the Airstream peeped for travel home and I used my recovery kit bug spray on them. I thought I had the problem solved. Nope. A few showed up over the past week, however, as I tried to remove the belly pan for A frame replacement...HORNET all over. Work stopped now for past two days.
Name:	1953 right side.JPG
Old 07-03-2015, 06:06 PM   #10
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
progress this week.
Thanks to Bruce Wood....I semi followed his guidance and replaced the A Frame. It needed to be extended for function....ability to fit a load control hitch and give some turning comfort zone ability.
Name:	1953 Airstream A frame new.JPG
ID:	242150   Click image for larger version
Name:	1953 Airstream new hitch Bulldog..JPG
Name:	1953 Airstream new A frame.1.JPG
ID:	242152   Click image for larger version
Old 07-12-2015, 09:37 AM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Today the value went DOWN
As I have tried to say many time....the minute you start the deconstruct of that "excellent condition" Airstream you got from Ebay or Craigslist, the value goes straight DOWN. You have also started down a very long and EXPENSIVE road. I have done this before. but it still bothers me.
Name:	deconstruct 11 July.JPG
ID:	242754   Click image for larger version
Old 07-12-2015, 02:42 PM   #12
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't do this
When you rebuild your Airstream interior....don't do it this way. I found this as I deconstructed the bed area. 2 x 4 lumber is good for barn building...not Airstreams.
Name:	old 2x4 bed frame.JPG
Old 07-12-2015, 03:01 PM   #13
bwoodtx's Avatar
1997 30' Excella
San Antonio , Texas
But, but, it IS sturdy!!
Bruce
Old 07-14-2015, 03:48 PM   #14
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
today, more inside
Having trouble removing the floor cabinet mount screws...the big ones. I guess slow but sure approach might work. The sink Galley cabinet base is also going hard and slow.....something is holding it in place. The bedroom are is now out. I can see the floor problem areas which will need replacing. The original Zolatone is visible now that the cabinets are removed.
Name:	original Zolatone rear cabinet.JPG
ID:	242969   Click image for larger version
Name:	Original Zolatone under rear cabinet.JPG
Name:	floor problem curb side rear.JPG
ID:	242971   Click image for larger version
Name:	rear floor problem area.JPG
Old 07-15-2015, 09:50 AM   #15
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Keep moving....or they get you
Vintage Owners will know what I mean...
Name:	Flamingo revenge.jpg
Old 07-24-2015, 09:46 PM   #16
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
axle swap
The belly pan has been cut out for replacement and floor inspection. The old sprung axles have been cut off and 1/4 inch angle welded to the frame the entire length go the wheel wells. Dexter 3500 lb tortion axles mounted to the reinforced angle/frame sections.
Name:	Dexter axle front left  reinforced.JPG
ID:	243840   Click image for larger version
Name:	Dexter axle spindle.JPG
Name:	Dexter axle spindle 21 degree.JPG
ID:	243842   Click image for larger version
Name:	Dexter axle with 1:4 in angle support'.JPG
Old 07-24-2015, 11:03 PM   #17
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Are you welding them on?
Old 07-25-2015, 06:40 AM   #18
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Yep! After talking with Dexter and a trailer manufacturer I went this way. They even have directions and sell angle mounts...like the 1/4 in angle I used, made for the welding installation. Where the supports are in the photos I have left original sections of the axle mount/frame reinforcements and will have them extend thru the pan for use as jack points.
Old 07-27-2015, 03:28 PM   #19
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
brakes and hubs
Awaiting the new tires and rims to complete the running gear.
Name:	Dexter brake and hubs.JPG
ID:	244023   Click image for larger version
Name:	Dexter Brakes and hub #2.JPG
Old 08-01-2015, 10:20 AM   #20
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
trial run new axles
seem to run straight and the height is good. Belly pan is next. Interior strip out at same time.
Name:	new axles height.jpg
ID:	244410   Click image for larger version
Name:	1953 Airstream Liner arrives home.JPG
Name:	1953 Airstream Line at Melody Ranch.JPG
ID:	244412   Click image for larger version
Name:	1953 Liner new axles.JPG
1947 Liner - "1006" :: 1947 Airstream Liner wdscentral Airstream Registry Discussions 3 04-07-2023 06:08 PM
Red Barn Safari Melody Ranch 1954 - 1959 Safari 101 01-29-2019 10:59 AM
Red Barn visitors Melody Ranch Cleaning, Stripping & Polishing 72 09-09-2013 01:10 PM
1953 Liner :: 1953 Airstream Liner 57BB Airstream Registry Discussions 0 07-16-2013 04:05 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
