05-15-2016, 12:24 PM
#121
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Near catastrophe
I went under the trailer today to hook up the brake wiring. I found that the trailer company which installed my axles had forgotten to put any...ANY....of the brake backing plate attach nuts on. This had left me with a free floating gear on my return home to the Red Barn. I got some locking nuts and now get on with it.
05-15-2016, 07:57 PM
#122
Central
, Mississippi
Wow. No nuts at all!!! My last axle job had 2 missing from dexter.
05-16-2016, 07:55 AM
#123
1953 32' Liner
1955 22' Safari
Valley View
Mid Century craze
The next time one of you "Generation" types plan a Mid-Century Rally....keep this in mind.
05-16-2016, 01:33 PM
#124
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Melody I love this.
"Get Smart" in shorts. I'm going to save this as a possible theme for one of our photo shoots some day.
Just add the dark rimmed glasses.
Hittenstiehl
05-17-2016, 09:51 PM
#125
1953 32' Liner
1955 22' Safari
Valley View
when old meets new
I bought the interior of a 2016 Cloud and have been trying to modify it to be usable in the 1953 Liner. Even though they are both 29 ft long the round corners of the 53 and the body width are giving me fits. Here is the booth and the hydraulic table will be installed for the completion. The long couch from the Cloud will be used as a lounge in the rear bedroom area after I get the frame of the curved base made. Pics later.
05-17-2016, 11:03 PM
#126
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel
, Oregon
This is a thread to follow! All eye candy! I envy your skills.
Thanks for sharing.
Susan
05-18-2016, 08:21 PM
#127
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Pull out a pair of your old checkered shorts, set up your thinking chair, and design a beautiful surround that accommodates the differences in body styles.
I saw this style dinette in a new Airstream at the RV show last winter. I was impressed with how sturdy and comfortable it was compared to the SOBs we looked at. I purchased one of the pedestal table lifts, and it works well.
I'm confident you will engineer a vintage looking solution for a great dinette in your old Liner.
David
05-28-2016, 06:57 AM
#128
1953 32' Liner
1955 22' Safari
Valley View
floor install sequence
I figured out the brake wiring location....I ran it in the wall above floor from the power distribution box up front to the wheel well area. So, now I can work the floor in readiness for the new wall panels. Luan will give me the smooth surface for the final flooring (to be picked and decided upon) installation. I may use a combo laminate and carpet like it came with.
07-07-2016, 02:39 PM
#129
1953 32' Liner
1955 22' Safari
Valley View
a break in the work
I got tired of working inside....so, at 105 degrees outside, and HUMID.....I am well into the polish sequence. Compounding don, now about done with the wool bonnet and Cycle next week.
07-07-2016, 07:27 PM
#130
1986 34' Limited
1975 27' Overlander
Conifer
If polishing is a "break in the work", then I've got the wrong perspective on what hard work really is.
Those mid summer Texas high temps are something else. They make even walking to the trailer seem like hard work.
Your vintage Liner is coming well along. Your expert polish job will make it very attractive. I bet it came from the factory pretty shinny also. I think your trailer was before the clear coat days. 2024 T32 aircraft aluminum comes pretty shinny right out of the box.
David
07-07-2016, 08:24 PM
#131
1964 17' Bambi II
Schererville
, Indiana
I will get to experience your Texas heat next week when I drive down to Willis with my daughter to start her career as a traveling nurse. It was too hot here today to do much outside without sweating bullets. Can't imagine polishing!!
Becky
1964 Bambi II
1988 Avion 32S
07-22-2016, 11:55 AM
#132
1953 32' Liner
1955 22' Safari
Valley View
Summer and still working
Well, Becky....it is only 105 here today, the 22nd. I hope your back home in the AC.
I am still trudging along....some final belly pan finish up and the interior walls on. Not really hard, however, finding enthusiasm is.
07-22-2016, 03:15 PM
#133
1973 31' Sovereign
Mount Angel
, Oregon
Well, this should aide in your enthusiasm: that is one gorgeous trailer! You're doing such a fine job.
Susan
07-22-2016, 04:06 PM
#134
1962 28' Ambassador
Mesa
Looking good, looks like a Mardi Gras float with the umbrella popping out.
Hittenstiehl
09-21-2016, 02:05 PM
#135
1953 32' Liner
1955 22' Safari
Valley View
misc items
Paint and reseal the rear compartment door.
09-21-2016, 02:07 PM
#136
1953 32' Liner
1955 22' Safari
Valley View
entry step installation
Got the new step installed. Now the exterior aluminum to finish it up.
09-21-2016, 02:10 PM
#137
1953 32' Liner
1955 22' Safari
Valley View
the work I hate
Windows are a pain and time consuming. However, they are a satisfying job. I use old bronze screening too.
09-21-2016, 02:11 PM
#138
1953 32' Liner
1955 22' Safari
Valley View
main door seal
did the main door and door within the door. Sealed up tight
09-21-2016, 07:41 PM
#139
1964 17' Bambi II
Schererville
, Indiana
so, so nice! You do great work, Robin!
Becky
1964 Bambi II
1988 Avion 32S
09-22-2016, 09:30 AM
#140
1962 28' Ambassador
Mesa
Melody Ranch that new door seal looks great. Did you use the VTS product or another source.
Hittenstiehl
