I am confused.
I'm struggling through the process of draining system and following the manual where I can. The manual tells me I need to work with the water heater bypass valve, which on my model happens to be located through the curbside storage access door.
Further, the manual states:...."
If valve is in-line with water line, turn byass valve clockwise to close."
Well, I found the valve already in the closed postion. (I assume perpendidular to water line means closed) The first picture is what I saw. That's the position in which the water heater has operated normally.
So then I turned this water heater bypass valve
counter-clockwise to the open position. See picture #2. Now the water drains out quite nicely underneath the trailer once I open the petcock.
So, what am I seeing wrong? If you follow the instructions above to ensure that the valve is in "
closed" position, then the water will not drain out -- the purpose of this exercise is to drain the system.
Hmmm...?
