07-29-2017, 08:32 PM
2013 30' Classic
Kent
What do use the outside 120V plug in for?
I understand the concept, but I'm curious how you use it? Outside TV? Radio? Anything else??
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
07-29-2017, 08:34 PM
1995 25' Excella
xxxxx
, xxxxxx
Phone charger
07-29-2017, 08:35 PM
2012 27' Flying Cloud
W
, New England
A small Fender bass amp to amplify my Timber uke bass from Magic Fluke.
I'll also sometimes set up my Dyson fan outside to keep skeeters and flies away.
We sometimes used it for external lights.
We've used it for our induction stovetop to cook breakfast.
There's no limits. [emoji3]
07-29-2017, 08:40 PM
2016 26' Flying Cloud
Southlake
Air compressor, fan
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
07-29-2017, 09:07 PM
2019 27' Flying Cloud
Kansas City
, Missouri
sometimes we forget to charge our bluetooth speaker so we just plug it in and put on the table by the campfire.
Piggy Bank
07-29-2017, 09:15 PM
ObviouslyKnot
KAILUA
, HI
Rat zapper! Gives the little buggers (mice) a grest place to stop off on their way into your trailer.
James Mileur, HY80-2-Al,
2017 Classic Twin, 2016 RAM 3500 Megacab, ProPride hitch
07-29-2017, 10:06 PM
2017 23' International
Santa Monica
Awning lights.
07-29-2017, 10:35 PM
Registered User
2016 25' Flying Cloud
Fairfield
Synthesizer and Fender amp, I can make cool ufo landing sounds at 2am.
07-30-2017, 12:27 AM
2013 30' Classic
Kent
Hey such great ideas, thank you. We've never used it before, just never had a reason. Now I can set up my own bug zapper, play music and much more. Thanks.
Yolanda (and Phil)
WBCCI #7878
07-30-2017, 12:59 AM
1999 34' Excella
Hillsboro
Lights... outside electric cooking devices to keep heat and odors out of AS... just keep within power design..and if CB pops... stop using stuff! I even replaced ours once (it was as not holding the plug properly. My wife used hair dryer on dog after its bath...
Peace and Blessings..
Channing
WBCCI# 30676
07-30-2017, 04:16 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
I plug in a small Dremel tool and use it to file down our dogs nails once a week.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
07-30-2017, 02:55 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
I have not done so, but there seem to be a lot of people parked here and there at the campground who use it for their coffee maker.
07-30-2017, 03:06 PM
Sag Harbor
, New York
Toaster, radio, hair clippers, extension cord for small corded tools for repairs, small microwave, battery charger for tool lithium batteries, etc. etc..
What do you use your exterior outlets for at home?
Same ol' . . . same ol' . . .
07-30-2017, 03:13 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
This outside duplex outlet has to have a GFI breaker in it's circuit since it is outside per the National Electric Code.
On our 2014 Classic, that was the breaker behind the microwave (yes the microwave had to be removed to access the GFI duplex socket to reset it as it that also had the outside outlet down stream). When we basically rewired the trailer, every outlet became a Hubbell 20 amp GFI commercial grade outlet that could also run on the inverter when on the 600 amp-hour lithium battery for power.
I added an additional single 120Vac outlet with a screw on cover on the back of our 2015 23D International Serenity just to the left of the rear storage access hatch. That is where I plugged in a heat tape for the exposed gray and black tank valves (kind of like the lion's balls hanging out there) to keep them from freezing when I first got to our RV Park on 29 April with a projected overnite temperature of 25 degrees. I could also run a cord up the rear support arm of the awning for a string of lights.
07-31-2017, 04:48 PM
Big Stone Gap
, Virginia
A simple box fan. With a propane fireplace the two have all but alleviated bug bites!
Chris & Sabrina
07-31-2017, 09:29 PM
2006 16' International CCD
Salt Lake City
, Utah
A blender to make the margaritas as close to the point of consumption as possible! Don't want to spill any. 😀
Stan
Salt Lake City
07-31-2017, 09:36 PM
2017 25' Flying Cloud
Fayetteville
, Arkansas
Electric skillet, electric knife (fish cleaning),
FishByFly
because I catch fish on a fly...
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
07-31-2017, 09:58 PM
I'm In
, Kentucky
I plug in the extension cord that's used to provide power to the charger attached to my Verizon Jet Pack that sits on a 10' pole attached to the popup. I have to do this only when the signal is weak.
Also:
Awning lights
Small electric leaf blower
Fan for skeeters
Lights under the awning of the popup and inside screened in tent
Laptop adapter (when I was working, retired now)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
08-01-2017, 01:18 PM
1982 31' Excella
Montgomery
I use the outlet to plug in the buffer to polish the exterior. I also plug in the electric trimmer to trim up my beard in the reflection; no hair clippings inside!
Chris P
'82 Excella 31'
'19 Ford F150 EcoBoost
Lake Conroe / Montgomery, TX
08-01-2017, 01:34 PM
Sag Harbor
, New York
Ditto to the . . .
Beard Here Now!
