Old 07-29-2017, 04:03 PM   #1
mojoe7009's Avatar
Green Cove Springs , Florida
Beeping noise when showering
I have strange one. When my wife takes a shower we hear a double beep every 15 or 20 seconds. Repeats about 3 times then stops. It doesn't do it when I shower. It is not the Co2 detector, smoke detector or the propane detector. It sounds like it is actually coming from inside the shower. It's crazy 2017 Classic
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 07-29-2017, 06:02 PM   #2
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Stephford wife needs new o rings?
sheriff1 is offline   Reply With Quote
Old 07-29-2017, 08:53 PM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
It's likely *not* inside the shower
To the left of the shower down low is the firefly panel with stuff behind it. To the right of the shower is the TV stuff and control panels for the sleeping area. Both are candidates for near by beeps. No idea what it would be past that.
Old 07-29-2017, 09:34 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Maybe it was some "smart ass" at the factory. They hid a smoke detector. Where it picks up moisture from the shower.
Does it happen when you use the shower?
Old 07-30-2017, 05:23 AM   #5
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Wild guess, but I'll bet your wife does not use as much hot water or set the handle as hot as you do and wondering if it has something to do with the Alde and the noise is actually at the panel and not "in" the shower. Try running the shower with no one in it at different temperatures and both of you try and find the noise would be what I would do, plus put one of my dogs to work and tell her to "find it" and she would.
Let us know what you find, if anything.
Bud
Bud
2020 28' Twin Flying Cloud-(Our 5th Airstream)
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) - 68-72
Old 07-30-2017, 05:47 AM   #6
Reads a lot
Titusville , Florida
Mojo......really? You have to be kidding.....I am totally convinced that you have the Airstream equivalent of Cristine. Your AS is messing with you. Have you considered calling a priest? When you figure out where the beep is coming from you gotta let me know, totally crazy.
Lauri
She Believed She Could so She Did.
kendrick.l.j is offline   Reply With Quote
Old 07-30-2017, 06:18 AM   #7
mojoe7009's Avatar
I am convinced the trailer is possessed as well. I got it back from JC and everything is working perfectly, INCLUDING the hot water! Then this weird beeping thing starts and tree limb fell on the road side rear corner and I have a nice softball size dent. I can't win. Maybe It does need an exorcism
Old 07-30-2017, 06:19 AM   #8
mojoe7009's Avatar
It only happens when my wife showers. Never when I'm in it.
Old 07-30-2017, 06:28 AM   #9
Reads a lot
Certainly do what Bud suggested and turn the water on at the level your wife usually uses it and both look for the beeping noise. There must be a logical answer. Then call your local Catholic Church, it couldn't hurt.
Lauri
Old 07-30-2017, 06:43 AM   #10
mojoe7009's Avatar
Bud
Actually she runs the water much hotter than I do. She took a shower yesterday and it didn't beep. We will see about today! I will try what you suggested. Hopefully it will beep and we can figure out where it's coming from.
Old 07-30-2017, 09:27 AM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
As for the dent. Look for my thread on how I removed the dent on my Argosy.
I would bet, with a small inner tube, some plywood and a shop vac you could remove that dent.
Old 07-30-2017, 04:15 PM   #12
1994 34' Excella
San Antonio , Texas
I don't have a clue; but love these kinds of challenges, for sure. Not being noisy but interested: what happens before the shower? Like, heating up a microwave to cook something while in the shower? Turning on a computer close by the shower to use after the shower? Taking off a wearable device and plugging it in for recharge and it alerting you to "charge complete". Perhaps a surge protector kicking in if the shower area is using a heated light, etc. Is there some type of 'water detector' being set off? Or does the A/S have a monitor panel that alerts you when water heater conditions change? Does the A/S have an on-demand electric water heater that sends out an alarm when in use? Oh well, good luck and break it down, keep it simple and check only one thing at a time. jd
delongj is offline   Reply With Quote
Old 07-30-2017, 05:12 PM   #13
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Probably not a hidden camera in the shower.......
2014 31' Classic model 30 twin beds, 50 amp service, 900 watt solar system, Centramatics, Tuson TPMS, disc brakes, 16" tires & wheels
Old 07-30-2017, 05:55 PM   #14
Vintage Kin
Fort Worth , Texas
" . . countdown to starship self-destruct sequence resuming".
Old 07-30-2017, 06:07 PM   #15
1974 25' Tradewind
Lexington , Kentucky
Sounds in shower
Does it do it only when you're backing up?
The Twinkie is offline   Reply With Quote
Old 07-30-2017, 08:05 PM   #16
Vintage Kin
Fort Worth , Texas
" . . yes, children, the Singularity began in an Airstream travel trailer when a random processor discovered an affinity for human females ."
Old 07-31-2017, 07:29 AM   #17
Box Elder (formerly of Center Moriches, NY) , South Dakota
NY24 is offline   Reply With Quote
Old 08-02-2017, 11:32 AM   #18
mojoe7009's Avatar
Beeping has stopped as mysteriously as it appeared and my dent is gone too! Local guy in Jacksonville, FL called "Never Happened". You be the judge. Click image for larger version
Old 08-02-2017, 12:01 PM   #19
2007 22' International CCD
No mystery. Sometimes temperature cycles make dents 'heal' spontaneously.
I have a 'tail drag' wrinkle that seems to be less a few years later...
Old 08-02-2017, 12:45 PM   #20
paiceman's Avatar
The dent is one of those times where I simply say "Huh" and move on.
Bud
Showering in our AS SillyRosie Plumbing - Systems & Fixtures 33 05-14-2015 07:04 AM
West SHOWERING in the Boondocks... Ray Eklund Boondocking 14 02-20-2015 12:08 AM
Beeping noise Glamper1 Sprinter and B-van Forum 5 01-03-2015 06:58 AM
Showering in your Airstream. CMSmith Our Community 44 06-28-2012 11:43 AM
Showering forestbrain General Interior Topics 7 10-15-2010 03:41 PM
