08-27-2019, 06:24 PM
2018 30' Classic
Rock Hall
, Maryland
Replacing Bathroom Sink
We have a 2018 30ft Classic. Has anyone replaced their bathroom sink? In ours, the drain is actually higher than the edges. It never drains completly. This has to be the worst design ever.
08-27-2019, 06:59 PM
2018 30' Classic
Thousand Oaks
Ours is fine. We have the same model. Can you take a picture? Could be a number of different things, Airstream should be able to warranty out if it is a design issue
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
08-28-2019, 10:16 AM
2018 30' Classic
Rock Hall
, Maryland
Picture of sink
here is the sink. See, it does not drain.
08-28-2019, 10:31 AM
2019 23' International
Portland
, Oregon
Same here
2019 International Signature 23FB "Cecil"
2020 RAM 1500 Laramie
Former coach: 2015 Bambi 16 "Beanie"
08-29-2019, 08:50 AM
2018 30' Classic
Thousand Oaks
Have you tried clearing the waterless catch? Maybe construction debris or hair is backed up in there?
I think mine is in need of cleaning as the draining is incredibly slow.
BigSxyWhtGuy
08-29-2019, 09:53 AM
Portland
, Oregon
On mine the rim is lower than the center
08-31-2019, 03:03 AM
2016 30' Classic
Lorton
, Virginia
Mine is the same. Poor quality control I think in the mold allowing the drain lip to be slightly higher than the basin. Really annoying to always have water there.
08-31-2019, 10:34 AM
Portland
, Oregon
Mine is metal and has the same issue
09-07-2019, 12:43 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Simple answer is to pull the drain fitting and clean up either the fitting or the sink insert as required. It's also possible that somebody got a bit carried away with the sealer when they did the assembly.
Even with the drain edge below the sink insert, it still drains *very* slowly. It will drain if things are exactly level .... good luck with that adjustment
09-12-2019, 09:31 PM
JP Patches
2019 30' Classic
Eden Prairie
AS replaced sink on our 2019 in July. Regardless of level, it would not drain. Seems better, now. Was not just poorly installed drain.
