Title:
I just posted a new ad on Airstream Classifieds.
I'm selling my ProPride 3P Hitch that I purchased a year ago for $2345.00. This Hitch comes with 1400# bars and has been used very little and is in excellent condition.
BUYER MUST PICK UP AT THE VAULT STORAGE IN LAKE WYLIE SC.
Specifications
Solid steel, durable design and construction
Patented yoke to eliminate trailer movement on the ball - even in panic stops
3/4" thick Pivot Point Projection control links
2000# rated weight distribution jacks
1400# weight distributing spring bars
Description
The ProPride 3P hitch is the most advanced trailer sway control hitch available for your towing needs. Jim Hensley, the man who revolutionized hitch performance with his old design, has improved and enhanced his new design for your extraordinary towing experience. With easy installation and use you'll experience towing stability and safety unmatched by any hitch available.
Details
The ProPride 3P main unit consists of two 3/4" thick links that project the pivot point of the trailer forward to near the rear axle of your tow vehicle. By not allowing the trailer to pivot side-to-side on the ball trailer sway is eliminated.
The ProPride Yoke keeps the main unit hitch ball from pivoting in the trailer coupler which would allow the trailer to sway.
Heavy duty weight distribution jacks allow you to distribute your tongue weight with precision and ease.
The 3P adjustable hitch bar is designed for any tow vehicle and trailer combination now and in the future. It includes a bar tilt feature to compensate for hitch receivers that are not parallel to the ground. This tilt allows more efficient weight distribution for varying hitch receivers.
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...ride-3p-hitch/
