06-03-2015, 04:57 PM
sequim
Andersen levelers and a 25'
just received two sets of these levelers. pretty heavy duty plastic i'd say. i took them out and set up one between the stock 15" wheels. it appeared it would clear OK when i backed onto them. have any of you used them to confirm that i don't have to trim them with the stock wheels??
06-03-2015, 05:22 PM
Princeton
, New Jersey
If you were able to use one between the wheels you are home free because the second one could be behind the other axle if you need higher lift.
So far I have only used one on a 16 in wheels with a 2x6 under both wheels.
2004 Excursion 4x4
06-03-2015, 07:14 PM
2020 Classic 33
Box Elder
, South Dakota
They fit fine on my FC. You might find it easier to pull forward rather than backing.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
06-03-2015, 07:52 PM
2015 25' FB Flying Cloud
Eugene
, Oregon
You will not need to trim them. I use them on our 25 with 16" wheels and they work dandily!
06-04-2015, 11:47 AM
2018 33' Classic
Newport
, Pennsylvania
I tried to put them between the wheels on my 2015 Classic with 16 inch wheels and I would need to trim them???
06-04-2015, 11:55 AM
2008 25' Classic
Full Time
If you are towing solo can one person use these? I currently use the Lynx blocks and have no issues when I tow solo but sometimes the trailer isn't level on the blocks but one more makes it go out of level the other way.
Kelvin
06-04-2015, 12:13 PM
2014 25' FB Eddie Bauer
Vero Beach
I use them on the EB25 with 16" wheels. They just fit between the tires. Whether you pull forward or back onto them, when you come off it helps to have an observer tell you precisely when to stop so you don't start to roll the other tire onto the big end and can pull the loose one from between the tires.
06-04-2015, 01:19 PM
Biloxi
, Mississippi
Kelvin
Solo Streamer here. Personally I think the Andersen Levelers are much easier for one person to use than blocks. No adding or removing blocks to get her level. Just roll back or forward the required amount and you are set.
MICHAEL
06-04-2015, 01:26 PM
2017 25' International
Carlsbad
No problem with 27FB
06-04-2015, 06:03 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Anderson Levelers
But they ARE expensive!
06-04-2015, 07:46 PM
Princeton
, New Jersey
Compared to blocks of wood yes. Something is expensive if it does not do the job you bought it for. As a user I do not think they were expensive as they provide the result I wanted and require little room while stored.
If you have a level the is visible in your review mirror it is a one shot deal to level and chuck. The second piece completes the chucking.
2004 Excursion 4x4
06-04-2015, 08:13 PM
Nevada City
+1 on the definition of expensive. The andersens work great. Leveling is a breeze with them. Probably the easiest part of setting up camp. Worth every penny.
06-05-2015, 10:03 AM
Morton
Work great on my 15" wheels. I love them.
06-05-2015, 01:36 PM
Manassas
, Virginia
The first time I used them the tire slipped sideways a little so when we got home I went to local hardware store and bought some outdoor tread tape and applied. They are so much better now.
They are a little pricey but like others have said they are worth it. No need to bring a limber yard with you anymore
06-05-2015, 07:50 PM
Newbie
2015 25' FB Eddie Bauer
Seattle
Love these levelers. Worth every cent for the ease of use. We have a 25' EB with the 16" wheels and I can set and remove them easily solo.
Andersen's weight distribution hitch is a thing of beauty as well! We use it to tow the 25 EB with a 2014 Jeep Grand Cherokee 4x4 diesel Overland and it pulls nicely! 18 miles to a gallon helps too!
06-11-2015, 09:08 PM
Slympicins
2015 27' Flying Cloud
Sevierville
, Tennessee
Those Anderson levelers are like sliced bread. Beats the pants off of anything else. If you need to change a tire just use one on double axles and change the other tire. They get a better level than the blocks as you don't have to add or subtract one to get it level. Just back up til it level. Poof.
06-11-2015, 09:12 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Owns Airstream, complains about $50 dollar product. #firstworldproblems
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
06-11-2015, 10:16 PM
Bend
, Oregon
LMAO! I do the same though, "$10 for a water hose!!!!"
06-11-2015, 11:50 PM
2016 25' Flying Cloud
Nanoose Bay
, British Columbia
I'll bite ... What's an Anderson leveller? Pic?
06-12-2015, 05:38 AM
2012 27' Flying Cloud
W
, New England
According to the Googlator 😃
I use them and love them!!
