Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 05-22-2008, 01:04 PM   #1
72 Overlander - Need Access Doors
Inherited the beauty from my grandfather (I used to camp with him as a child). It has seen some rough years - and I want to start the process of fixing it up (and using it as well). To start, I need to find a couple of parts (without them it is difficult to use)
I need:
External Access door for battery compartment
External Access door for Fridge access
Air Conditioner cover.
If anyone knows of someone with these doors/cover, please pass along the information. I am located in Western South Dakota and can travel if needed...but if can be shipped, that'd be Great!
Contact me with any additional information - Ill be browsing these forums for tips and info for my restoration project!
NorthernHill is offline   Reply With Quote
Old 05-22-2008, 01:50 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Do you know the deminisions. I have both of the doors off of a 71
Old 05-22-2008, 02:32 PM   #3
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Welcome to the Forums!
I found a second access door for our 1976 Overlander on E-bay after much searching. I started to watch E-bay on a regular basis and was suprised that I would see doors and other parts from time to time.
Good luck!!
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2020 GMC Denali Duramax
Hensley Hitch
vajeep is offline   Reply With Quote
Old 05-24-2008, 09:48 AM   #4
Door Dimensions
Have measured (take into account the trim is still intact so measurements may be close depending on where you measure from)
Battery access door (19W X 11H)
Fridge access door (20.5W X 14.25H)
Looks like the fridge access door has the remnant of a hinge (still in the trim-and swings like was attached to the door) - and the battery access door has the same upper trim groove - but no remnant of a hinge. I dont know if they utilized a hinge or not...perhaps someone with a working door can enlighten me...
Let me know if any of the doors anyone has will work!
Thanks!
Old 05-24-2008, 12:51 PM   #5
Aerowood's Avatar
Arvada , Colorado
Both of mine are 20.250 X 14.250
Old 05-26-2008, 08:59 AM   #6
My Mistake - Not battery compartment - but storage!
OOps! Got to working on the trailer this morning and realized that it is not the battery access door that is missing, but the storage door (under the rear bed)
Dimensions are as posted earlier...
Thanks!! (Even if you only have one, that'd be great -eventually I hope to find both!)
J
Old 06-22-2008, 09:47 PM   #7
2005 22' Safari
Half Moon Bay , California
72 Tradewind - Complete battery compartment is available. Holds one series 27 batteryl This was curbside behind the rear axles, above and below the plywood floor. Includes lock and key, plastic shelves, and both the permanent housing and the door. Hinge adrift. Shipping from CA. jim jsutro@coastside.net
jsutro is offline   Reply With Quote
Old 06-23-2008, 02:08 AM   #8
I need:
We have the AC covers, and the original Airstream molds.
They are made with fiberglass, and have a white "gel coat" exterior finish.
Andy Rogozinski
Inland RV Center
Corona, CA
Access compartment doors 1976 A/S adonh Doors & Locks 11 11-04-2007 01:25 PM
Genset access JBK Airstream Motorhome Forums 9 02-02-2007 05:16 PM
Threshhold and Access doors mbatm01 Repairing/Replacing Floor &/or Frame 12 09-25-2004 07:53 AM
Access Doors and Keys AlanH Doors & Locks 3 06-11-2004 10:36 AM
