Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 07-16-2018, 06:44 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Water tank covers, do they Support?
I'm removing my belly pan, are the water tank covers supporting the tanks or just protecting them? Asking so I know how to proceed.
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 07-17-2018, 05:26 AM   #2
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
Tank covers/pans support the tank on my 2014 unit. There are 4 metal straps that are on the outside of the tank pan that provide support.
Old 07-17-2018, 05:48 AM   #3
Re-Pete's Avatar
1992 29' Excella
Thanks for your feedback. My 1992 does not have straps on the exterior of the metal cover.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
Old 09-15-2018, 01:01 PM   #4
Re-Pete's Avatar
1992 29' Excella
Here's a follow up I should have done a couple months ago.
The Belly Pans on my 92 Excella run up to the Water Tank pans in the front and rear. The Freshwater Tank Pan is located between the Front and Rear axles. The Gray and Black water tanks are in one Pan located just behind the Rear axle. So, all together there are two pans and each pan has a flange on all four sides with holes approximately 12" apart that allow 5/16" Flange bolts to secure it to the chassis frame. The pan alone secures the water tank/s. When the pans are dropped the water tanks come with them. In my case, even with the bolts removed the pans were still difficult to drop. They were stuck in place. I had to pry them loose. Also, make sure that you've disconnected all of the hoses and pipes from the tanks. I had overlooked the fill hose for the fresh water tank. It didn't cause any damage, it just caused it to hang up. The pans are lined with 1" Polystyrene panels as insulation.
Pete
Virginia Beach, VA
Mega Cab Diesel 4x4
Old 09-15-2018, 01:51 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
My 2001 Safari had plastic pans with external metal straps. The straps obviously did the heavy lifting. My 2002 Classic has galvanized steel pans with closely spaced bolts and nothing else holding the tanks.
Al
Old 09-15-2018, 02:05 PM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
That the pan supports the tanks suprises me . on my 1988 models the tanks are supported by straps inside the area of the pan.
New axles - they're here, and they will require... drboyd Axles 34 07-17-2016 12:55 PM
Electric Grills, do they not get hot enough, are they a waste of time? adiben On The Road... 17 06-01-2015 10:45 AM
Roof Lockers - How Much Weight Can They Support? JFScheck General Interior Topics 8 04-07-2011 01:18 AM
Kitchen drawers-can they support weight? femuse Cabinets, Counter Tops & Furnishings 7 10-29-2004 06:13 PM
They don't make them like they used to femuse Our Community 23 04-29-2003 07:15 AM
