Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-07-2004, 10:37 AM   #1
mbatm01's Avatar
1963 22' Safari
Broomfield , Colorado
BellyPan and Wheel Well Caulking/Sealer
I am finishing the shell off floor replacement, when I pulled the wheel wells - the caulking that the factory used was still very flexible and sticky after 41 years. What should I use to re-seal the wheel wells to the wall and frame when I replace them? Any ideas what AS used originally?
Do I use Vaulkem between the floor channel, belly pan and shell?
Kevin
mbatm01 is offline   Reply With Quote
Old 09-07-2004, 11:32 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Kevin
Kevin,
I used Vulkem. It stays workable for a long time, does not harden as quickly as Sikaflex.
My Airstream also had a coating of vehicle seam sealer over the wheel well joints, where they meet the side skin.
Uwe
www.area63productions.com
Old 09-07-2004, 06:19 PM   #3
Tinsel Loaf's Avatar
I just did my wheel wells to keep dirt and water fron getting inside. I removed the wheels one at a time for safety and jacked one side up right under where the shock attaches to the axel frame. Cleaned everything really well and used vulkem 616. It got into the crevices sealing and adhering very well, easy to work with.
Tinsel Loaf is offline   Reply With Quote
