Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 06-24-2009, 01:05 PM   #1
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Steps drop down while driving 1962 Flying Cloud
The steps on our Flying Cloud occasionally drop down while we are driving. Other than that they are solid, work pretty well and operate normally. Any suggestions?
Thanks!
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 06-24-2009, 01:33 PM   #2
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Thanks!
FLYNCLD
I know how to fix that problem! I will buy the trailer! I sooooo badly want a 62 flying cloud!
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 06-24-2009, 01:36 PM   #3
Levon's Avatar
Profile:  1967 17' Caravel
1989 25' Excella
Colbert , Georgia
Images: 158
Greetings FLYNCLD,
I have had several steps on different models drop down while driving. If yours releases by pulling out the front metal in the center of the step, you might can take some pliers and bend slightly to tighten while in the closed position...it worked for me on 3 different trailers. Hope that helps.
Best Regards,
Levon
Levon is offline   Reply With Quote
Old 06-24-2009, 01:59 PM   #4
VIKING's Avatar
Profile:  1964 22' Safari
Boulder Creek , California
My safari has a metal strip running across the front of the step when closed. There is a small metal bracket welded to this strip that holds the step up. if you have the same thing you need to look at the bracket and determine if it's worn out or bent. If bent you can take a hammer or something like that and bang it back just a little, so it engages the step better. Too much and you will have a hard time opening it!
If worn/ rusted out, you will need to have one made up and attached to replace it.
If you have a completely different set-up from that...
This message will self destruct in five seconds
Good luck,
Rich
See my blog: http://1964airstreamsafari.blogspot.com/
VIKING is offline   Reply With Quote
Old 06-24-2009, 02:11 PM   #5
FLYNCLD's Avatar
Bend , Oregon
Thanks for your help...mine does pull out from the center, so I will try tightening it up with a bigger hammer!!
And no..she's not for sale! LOL
FLYNCLD
Old 06-24-2009, 09:48 PM   #6
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
1956 30' Sovereign of the Road
Southeastern Area , Tennessee
Rich, If your step is like mine on the '60, it's all about the little metal clip. Check this post by Mark Doane. Mark's infinite knowledge base has helped me out of a jam more than once.
TRAVELING WITH ELVIS
LIFE WITH A 1956 SOVEREIGN OF THE ROAD
• • • Aluminocentricity • • •
WBCCI# 14674, Washington DC Unit
Sugarfoot is offline   Reply With Quote
Old 06-25-2009, 10:09 AM   #7
VIKING's Avatar
Thanks Sugarfoot,
The pics say it all. That's one thing I haven't taken any shots of, myself. I lucked out. My step works like a charm. When I pull out on the handle it shoots out and locks into place nine out of ten times, without any assistance.
Sweet!
I love Elvis. A pre '57 is my destiny. I just know it.
Rich
1962 Flying Cloud FLYNCLD WBCCI Forum 6 02-02-2009 08:54 PM
1962 Flying Cloud Electric Brakes smcpheters Brakes & Brake Controllers 18 08-03-2008 04:20 PM
55 flying cloud, how much? Lychgate Trailer Values 5 07-11-2007 06:14 PM
help with a 62 Flying Cloud stevenormand 1962 Flying Cloud 1 02-24-2006 09:28 PM
I think this is a 55 flying cloud?? jaynshae 1955 Flying Cloud 5 09-05-2004 10:50 PM
